Front End Limiters and Reaction Time
#1072898
09/11/11 01:15 AM
09/11/11 01:15 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
My brain says letting the front end of the car travel further before the suspension moves would give me a slower reaction time, but I swear reality is the opposite....Which gives a faster reaction time, limiters limiting or not limiting?
Oooh and a new best tonight 10.42 at +127mph....But we ran 1/8th but I got a 1/4 run in before they changed timers....I ran 6.63, 6.63, 6.63, 6.62 tonight...Bulbed it. Glad I haven't lost my lucky streak.
Re: Front End Limiters and Reaction Time
[Re: Dragula]
#1072899
09/11/11 02:39 AM
09/11/11 02:39 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
This is one of those things that you have to try, maybe several different times depending on which track and track conditions , on your vehicle to see what works the best I have seen stiffer shocks slow reation times down on a NHRA Stocker that redlighted a lot Not so on shortening the front end travel on the same car
[Re: Dragula]
#1072900
09/11/11 10:49 AM
09/11/11 10:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Its dependent on how the front end acts now... if it just yanks the front straight up or if it rolls forward then up... what are you looking for... faster or slower RTs
[Re: Dragula]
#1072901
09/11/11 10:58 AM
09/11/11 10:58 AM
Posts: 5,898 Florida
Locomotion
I never liked the idea of limiting front end travel with stops. Different shocks or setting worked well for me because traction is a priority. As for RT's, I adjusted tire size and fine tune with air pressure. I can't say for sure if limiters slow or speed up RT's because I never tried it. But my brain says limiters would speed up RT's a bit because it keeps the car from rotating/transfering, so it can only travel forward. There are several "it depends", including if it yanks the wheels or rolls them out of the beams on the initial hit. I think it can "pop" the wheels up, out of the beams faster with stops!
[Re: Dragula]
#1072903
09/11/11 11:06 AM
09/11/11 11:06 AM
Locomotion
The ones on the car are more of an adjustable bump stop. We have upper and lowers we custom made at the shop. Ron adjusted the lowers higher limiting the travel, and when I stage and just barely break the beam the RT is horrible. I have to nearly deep stage to get any kind f RT..
There goes my theory, at least in your particular set-up.
[Re: Dragula]
#1072904
09/11/11 11:12 AM
09/11/11 11:12 AM
MR_P_BODY
How do you leave now.. foot or trans brake... RPM would help... rear set up also would help... what is on the rear.... does it lift the fronts
[Re: MR_P_BODY]
#1072905
09/11/11 12:08 PM
09/11/11 12:08 PM
Dragula
2800rpm leave on the foot brake. Stockish front suspension. Rear is a 4-link with single adjustable shocks. Typically trying to get it to leave straight and level...
[Re: Dragula]
#1072907
09/11/11 12:25 PM
09/11/11 12:25 PM
MR_P_BODY
Do you have a anti roll bar on the rear
[Re: Dragula]
#1072910
09/11/11 12:48 PM
09/11/11 12:48 PM
MR_P_BODY
No anti roll on the 4link. Just tuning the bars to leave straight...
Well a anti roll WILL plant both rears better... I would add one... I wont build up a 4 link car without one
[Re: MR_P_BODY]
#1072912
09/11/11 01:23 PM
09/11/11 01:23 PM
MR_P_BODY
If you look at the RR tire you can see that the outer and inner 1" or so is NOT in contact with the track... most people think that the car is rolling over to the right rear but in reality the right rear tire is rolling UP into the wheel well trying to roll around the drive shaft and the left rear tire is planting harder than the right... this is where the anti roll CAN help plant both tires... if you can up the launch rpm that would help the RT.... if you dont roll (the body does roll but not like most think)
[Re: Mopar-Al]
#1072914
09/11/11 07:28 PM
09/11/11 07:28 PM
MR_P_BODY
My 68 dart has front end limiters on it. But no anti roll bar installed. For what it is , it does ok as far as I can tell. Tube chassis , coil overs, rack n pinion, ladders bars set in the middle hole wheelie bars set at 2.5 inches. Leaves straight and hard. Most of the time I trans break it, when I flash, I leave at 2800. My wheels don't come up but an inch or so, but the limiters are loose to 2 inches or so when front end is relaxed. I only 60' like 1.36 or so usually tho. On a bad prepped track around 1.50
You would only need a anti roll to cover up for flexing so if it doesnt flex much you dont need one (on a ladder bar car)
[Re: Mopar-Al]
#1072916
09/12/11 10:57 AM
09/12/11 10:57 AM
Dragula
No anti roll for this year, but maybe next year. As for reaction times, I usually adjust front tire air pressure, but I am maxed on that, raise launch rpm, I can, but it hits the tire harder and might not be as consistant...What about adjusting the limiters?
