Plating on Original E Body Gas Tanks ?? #1072454
09/09/11 11:48 PM
09/09/11 11:48 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
I was looking at some pictures of a NOS Challenger gas tank on eBay(and have looked at others over the years) and noticed there is a big difference between an original/NOS tank and a new reproduction when it comes to plating/finish.Did they originally have a different type of plating/coating on tanks back in the 70's or was it some type of film that was on the flat metal before the tanks were stamped out?It looks much duller/flat/matte finish then the reproduction tanks that are shiney.Almost like a light coat of phosphate maybe.Just courious if anybody knows.
Re: Plating on Original E Body Gas Tanks ?? [Re: 44D6PAKCUDA] #1072455
09/10/11 01:31 AM
09/10/11 01:31 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Most if not every steel gas tank from the muscle car era was made of ASTM A308 terne sheet, which is steel sheet coated with an alloy of lead-tin by the hot dip process. See http://www.astm.org/Standards/A308.htm
This spec discusses the coated steel sheet is suitable for solderability, corrosion resistance, and gasoline resistantance.
As far as I know, all reproduction gas tanks are made by Quanta. See
www.gastanks.com
Quanta states that all their tanks are made of “Corrosion Resistent Ni-Terne steel”, which sounds close to A308 or the same as A308, except A308 does not mention Ni (nickel) in its title. (You can’t read the details of A308 chemistry online unless you pay money.)
New Quanta tanks are shiny, and old NOS ones would have some oxide of lead-tin on the surface. I’m not sure what color tin turns after long atmospheric exposure, but I think lead turns dark gray. I suspect the only difference between new and old terne sheet is just discoloration from atmospheric oxidation, as long as there weren’t other sources of corrosion.
I suppose it is possible there is someone out there making tanks from galvanized sheet. It's really hard to tell the difference between terne and galvanized sheet just by looking. It should be better to solder the two halves together and make a leak proof joint with terne than galvanized (zinc).
Re: Plating on Original E Body Gas Tanks ?? [Re: kentj340] #1072456
09/10/11 11:11 PM
09/10/11 11:11 PM
Kent-Thanks for the great info.Is there any way of plating a new tank with the lead-tin type plating they used before to get an original look,or is it even used today with all the EPA guidelines?
Re: Plating on Original E Body Gas Tanks ?? [Re: 44D6PAKCUDA] #1072457
09/11/11 06:23 PM
09/11/11 06:23 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
There is no practical way to do that. your best bet is to knock down the shineyness of the new tank using an etching solution. Vinegar, lemon juice, paint prep/galvaprep, acid solution, etc. ....try it on a pce of galv or the top of the tank until you get the look you are looking for.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Plating on Original E Body Gas Tanks ?? [Re: DPelletier] #1072458
09/12/11 12:37 PM
09/12/11 12:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
RPM dulls the surface of the part you use it on. You can polish it once it's dry to get the shine back. You could try RPMing the tank but don't polish it after. It will dull down the shine a little. I don't know if it would dull it down enough for your needs though.
Re: Plating on Original E Body Gas Tanks ?? [Re: 44D6PAKCUDA] #1072459
09/13/11 03:45 AM
09/13/11 03:45 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
New repro gas tanks are already made with lead-tin coated steel. They are exactly the same as original tanks as far as the lead-tin coating appearance. The shiny terne coating looks exactly the same today on repros as it did on new Mopar originals back in the day. The steel mill process is mostly unchanged from before the 1960's, except for improved production control and quality control through better computerization.
If you want an original factory look for a gas tank, the shiny repros deliver this, and the NOS tanks don't, because they are old. The NOS ones are dull colored due to aging, just like today's repros will be too after some years of atmospheric exposure. (Besides, it might be possible there could be some corrosion inside an NOS tank from condensation caused by temperature and hunidity changes during long storage.)
You might be able to keep a repro tank shiny like tanks were when a new car left the factory by using wax or other preservative on the outside. But undercoating overspray from the rear wheel wells might not stick on a waxed tank like it did on original tanks.
Terne sheet for making gas tanks, sometimes called long terne sheet, is cold rolled steel sheet that has been hot dipped in a molten bath of lead-tin in a high speed continuous process at a coating mill. Lead is still used for this just like it is still used for solder, since lead safety is not an issue with these.
I looked into the use of nickel in the terne process, since Quanta says they use nickel-terne steel. Ni-terne sheet gets a flash coat of electro-deposited nickel on the steel before hot dipping. The nickel is there to improve corrosion resistance.
A range of coating thicknesses, alloys of lead-tin, steel grades, steel thicknesses, etc., are available under ASTM A308 for making terne. Hard to say if repro tanks are the same as originals in all of these quality details, even though the appearance is the same. Since Quanta has chosen to use Ni-terne instead of terne without Ni, that tends to say that Quanta strives for quality. I bought a Quanta tank since my original was toast. But so far it is still in the box. Although there are complaints about Quanta's belts, I have not heard any complaints about their tanks. I figure Quanta is a tank making operation that doesn't make anything else, and they buy the belts and other stuff for resale.
Re: Plating on Original E Body Gas Tanks ?? [Re: kentj340] #1072460
09/13/11 07:28 AM
09/13/11 07:28 AM
Kent-Thanks for some more great info.The few NOS tanks I have seen all had the "aged" looked to them and I always thought there was some other plating used before the EPA got involved.Now after looking at the tank in my car that has been in there for close to 6 years it is started to tone down a bit also.Thanks again for the info!!
Re: Plating on Original E Body Gas Tanks ?? [Re: 44D6PAKCUDA] #1072461
09/13/11 09:03 AM
09/13/11 09:03 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Here's a few shots of an NOS Cuda tank I have...same finish.
Scratches on the finish but no dents whatsoever
Re: Plating on Original E Body Gas Tanks ?? [Re: mccannix] #1072462
09/13/11 09:05 AM
09/13/11 09:05 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
the black sealer or whatever it was called, used along the seams, not seen on repros
Re: Plating on Original E Body Gas Tanks ?? [Re: mccannix] #1072463
09/13/11 09:06 AM
09/13/11 09:06 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
got carried away a bit on the corner...
Re: Plating on Original E Body Gas Tanks ?? [Re: mccannix] #1072464
09/13/11 09:06 AM
09/13/11 09:06 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
closer shot of the finish..
Re: Plating on Original E Body Gas Tanks ?? [Re: mccannix] #1072465
09/13/11 09:10 AM
09/13/11 09:10 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
This sat in an old storage school bus back of a Chrysler dealership for 20 years until I got and have had it since.
The elements played a part in it not being pristine, however, the inside of the tank is...
Re: Plating on Original E Body Gas Tanks ?? [Re: mccannix] #1072466
09/13/11 09:40 PM
09/13/11 09:40 PM
Terry-I was almost relieved when I saw your tank was a 4 nipple version instead of a single one like my Cuda would need Thanks for posting some great pics.Are you in agreement with Kent on the oxidation that occurs to the tank plating over the years?
Re: Plating on Original E Body Gas Tanks ?? [Re: 44D6PAKCUDA] #1072467
09/13/11 11:12 PM
09/13/11 11:12 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Yes I would agree with Kent on that, no matter how it was stored.
Re: Plating on Original E Body Gas Tanks ?? [Re: mccannix] #1072468
05/05/14 01:44 AM
05/05/14 01:44 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Quanta is apparently not a gas tank maker and is re-selling Spectra tanks.
Re: Plating on Original E Body Gas Tanks ?? [Re: kentj340] #1072469
05/05/14 09:16 PM
05/05/14 09:16 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Yes, the box even has the same Spectra numbers on it. I got mine from Rock Auto for $80 less. $$$$$$$$$$
