Broke a valve any input. #1072294
09/09/11 07:02 PM
09/09/11 07:02 PM
IN
67Dart383 Offline OP
IN
I've got a 67 Dodge Dart with a 383. Last fall I broke a valve right at the keeper. I was wondering what caused this? I have had a few people tell me bad valve springs can cause this but I had them pressure checked and they checked out to speck. Prior to the valve braking it would stop pulling in first or second gear around 5000 rpm. Never both gears which was weird. Which would remind you of a valve spring problem. So I need to get the head fix but am afraid of this happening again. Fortunately it didn't hurt the short block this time.
Re: Broke a valve any input. [Re: 67Dart383] #1072295
09/09/11 07:06 PM
09/09/11 07:06 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
What heads? What valves?
Re: Broke a valve any input. [Re: 340_Dart] #1072296
09/09/11 07:15 PM
09/09/11 07:15 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
May sound wierd, but a stiffer spring is better on the valve than a weaker spring. The float, and resination, (sp) is what kills valves. Just check this video out on youtube, and see how much work a valve spring does, and the torture it goes through.
http://www.youtube.com/watch?v=kFbfHF9gzTY
Kasey
Re: Broke a valve any input. [Re: Moparnut426] #1072297
09/09/11 07:16 PM
09/09/11 07:16 PM
Moparnut426 Offline
Moparnut426  Offline
Re: Broke a valve any input. [Re: Moparnut426] #1072298
09/09/11 07:20 PM
09/09/11 07:20 PM
Moparnut426 Offline
Moparnut426  Offline
Re: Broke a valve any input. [Re: 67Dart383] #1072299
09/09/11 08:03 PM
09/09/11 08:03 PM
IN
IN
452 Casting with 2.08 intake that broke. MP 284/484 camshaft Mopar performance valve springs.
