how much loss with six pack (small block stroker)? #1071946
09/09/11 12:02 PM
09/09/11 12:02 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys, still debating over induction on my small block stroker....
car is an AAR, so it'll be nice to retain some type of 6 barrel induction (although not necessary, i don't drive with my hood open), and i was (still am) considering efi six pack.
in the interest of minimizing the vacuum in my wallet, i'm contemplating just running the standard carbed intake that i already have, but am wondering how much power i would be sacrificing.
Thanks for any input!
p.s. engine is fairly mild (450~500ish hp)
Re: how much loss with six pack (small block stroker)? [Re: kielbasa] #1071947
09/09/11 12:39 PM
09/09/11 12:39 PM
Delray beach, Florida
P
Performance Only Offline
P
on a mild build, i think the better question would be how much gain, if done right. if your goal is what you stated, the six pack will easily get you there.
machine shop owner and engine builder
Re: how much loss with six pack (small block stroker)? [Re: kielbasa] #1071948
09/09/11 01:01 PM
09/09/11 01:01 PM
I have a freind who ran a 1970 Chalenger T/A in NHRA stock, he made the power you want easily with the six pak He set the NHRA C/SA record with it several years ago. NHRA factored his car so he hasn't race it lately If you put a 440 center carb on it it will make more power, not a bunch more but more
Re: how much loss with six pack (small block stroker)? [Re: Cab_Burge] #1071949
09/09/11 01:45 PM
09/09/11 01:45 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Power loss over what?
Re: how much loss with six pack (small block stroker)? [Re: scatpacktom] #1071950
09/09/11 02:07 PM
09/09/11 02:07 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
i should have specified...
a modern 4 barrel
Re: how much loss with six pack (small block stroker)? [Re: kielbasa] #1071951
09/09/11 02:33 PM
09/09/11 02:33 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
If set up right? NONE
Re: how much loss with six pack (small block stroker)? [Re: Valiant_Showoff] #1071952
09/09/11 04:01 PM
09/09/11 04:01 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Even if it was 15 or 20 would you worry about it?
Re: how much loss with six pack (small block stroker)? [Re: scatpacktom] #1071953
09/09/11 04:18 PM
09/09/11 04:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know when Mopar Muscle did a dyno shootout on intakes for the bigblock the 6pk made almost as much as any of the modern single four intakes. It surprised me how good the 6pk did. Ron
Re: how much loss with six pack (small block stroker)? [Re: kielbasa] #1071954
09/10/11 03:22 PM
09/10/11 03:22 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
The Oct/08 car craft did a story on the MP 410 6 pack crate motor. Might
be of interest to you, 469hp/490tq.
Re: how much loss with six pack (small block stroker)? [Re: kielbasa] #1071955
09/10/11 07:00 PM
09/10/11 07:00 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Using Vizard's rule ("find the restriction"), as power goes up the limited plenum volume of a 3×2 becomes a problem. At 400 it doesn't matter, at 700 it's fatal. In between...??
More cam, and especially overlap, is also tough because it upsets all the original careful jetting and leaves you playing with your drill set and cursing.
Boffin Emeritus
Re: how much loss with six pack (small block stroker)? [Re: 383man] #1071956
09/10/11 11:04 PM
09/10/11 11:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my 440-6 seems to run plenty strong...even w/o aftermarket metering plates and junk... No reason a 6-pack can't run w/ a 4bbl. As a matter of fact it will pick you up more ponies unless it's an all out race car.
Coming soon!!!!
Re: how much loss with six pack (small block stroker)? [Re: polyspheric] #1071957
09/10/11 11:09 PM
09/10/11 11:09 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
The oem modified intake works well, even with modified carbs but on more or less cookie cutter small block stroker with heads in the 285-295 real world area mine would start to go flat at 6700 or so.
I now have the indy mod man with the big plenum under what amounts to a 1.5 spacer above the plenum and with some adjustments its the one thing the motor really needed, happy at 7k but seems to go alot further if needed.
If you have a stick or a mild vert/gears the mod man is somthing to consider.
Opinions will vary on six packs in as many ways as any mopar topic, its just a different but fun fuel delivery system.
Re: how much loss with six pack (small block stroker)? [Re: quick77rt ] #1071958
09/11/11 10:41 AM
09/11/11 10:41 AM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
OK- i know you said smallblock but I think this may help.I had a 69 Superbee and was running a stock style 6-pack. Car was running 12.60's at the time and I had an M-1 single plane intake and a new Holley 750 vac. secondaries carb.Went to the track and made 2 passes with the sixpack.12.60 and 12.61. Switched the intake and carb to the 4 barrell and went 12.61 and 12.61. So in my application I saw no difference. When I installed the new engine it ran a best of 11.60 with the sixpack and didnt put a four barrell on that combo.
Re: how much loss with six pack (small block stroker)? [Re: kielbasa] #1071959
09/11/11 05:40 PM
09/11/11 05:40 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
No losses, just gains. Stop thinking so hard.
Six packs rule
Re: how much loss with six pack (small block stroker)? [Re: kielbasa] #1071960
09/11/11 08:06 PM
09/11/11 08:06 PM
a modern 4 barrel
I dnyo tested my low deck sixpak motor(518 C.I. Pump Gas) with the sixpak and then 30 minutes later a Team G intake and 1050 Dominator, I actually tested three different Holley 1050 Dominators and I had to add a Wilson Manifold 2 inch reversion spacer to get the single, modern, four barrel carb. power close to that old design sixpak on that motor The best dominator on the Wilson reversion spacer made 708 HP and 750 Ft. Lbs and the sixpak made 718 HP and 750 Ft Lbs, same dyno, same day More air with the proper mixture of fuel made more power
Re: how much loss with six pack (small block stroker)? [Re: Cab_Burge] #1071961
09/11/11 08:58 PM
09/11/11 08:58 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
this may not be an apples to apples comparison but i took the 6-pak off my 69 r/t this weekend and put the stock 4bbl intake and carb on. the engine is basically stock and i've had a 6-pak on it for over 20yrs. anyhow, talk about a power loss! on another note here, i used to build a 440 bracket motor for this guy and it started out with a 6-pak. anyhow, all his know it all pals told him he needed a team-g intake and dominator carb. about $1000 later the car didn't run any quicker when it had with the 6-pak on it. multi carb or no carb .
Re: how much loss with six pack (small block stroker)? [Re: BEEQUIK] #1071962
09/12/11 01:19 AM
09/12/11 01:19 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Mine was the same went 11.53@117 with 6 pack and 11.58@116 with M1 and 850 Holly.Same day about 15 min.between passes.Just took one intake and carb off put other on.
Re: how much loss with six pack (small block stroker)? [Re: pro6pakRR] #1071963
09/12/11 05:11 PM
09/12/11 05:11 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
My dialed in 416/six pack was 499. My 416 with an airgap from the dyno room/950 Holley was 536. Manifold is a restriction on bigger power. 440 six packs were better. That all said, I still have the 6 pack on the car.
Re: how much loss with six pack (small block stroker)? [Re: BobR] #1071964
09/12/11 05:55 PM
09/12/11 05:55 PM
Keibasa, I had to jet my outboard carbs way up to get it to make more power than the 1050 Dominator did, 66 or 67 jets in the center and .092 or .094 on the dirver sides and .096 or .098 on the passenger side outboard carbs depending on the track elevation and current weather Most stock jetting on the factory sixpaks sucked wind big time
Re: how much loss with six pack (small block stroker)? [Re: Cab_Burge] #1071965
09/12/11 07:24 PM
09/12/11 07:24 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Anyone care to take a stab at a better real world discription of having the large plenum down low as on the mod man, possibly the pros/cons as really Indy-s explaination is semi vague and maybe if more understood them they would sell more.
I will say one last time, mine with a 1.5 spacer above the plenum seems to be as good down low and way better up high, but I will only have chassis dyno numbers to compare, no dyno or track specs, but its very easy to tell the diff between an oem dual and a performance single plane.
