Re: Solid Cams who runs them?
[Re: 493_DART]
#1071779
09/09/11 09:46 AM
09/09/11 09:46 AM
Posts: 117 Muskegon Mi
dcr
Muskegon Mi
Solid here also running a hand me down that was replace with a roller and I think at times he wonders why he botherd he really dident gain a thing and Ive went 10.35 130mph in 3200 lbs car with only 11-1 compression.Useing brad penn oil and this cam is about 10 years old.
[Re: 572B1]
#1071784
09/09/11 11:53 AM
09/09/11 11:53 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I run a solid flat tappet cam custom ground by Dwayne Porter. It was nitrided and I broke it in about 3 months ago. I used Valveoline racing oil and the comp oil additive with the zinc in it. Broke in fine and has been zero problems. Ron
[Re: SCATPK]
#1071787
09/09/11 03:36 PM
09/09/11 03:36 PM
Posts: 20,667 in a cattle trailer down by th...
Guitar Jones
I've had a Hughes flat tappet solid in my small block for about 15 years. I've never had anything but Mobil1 10w30 in it, no additive ever. I did like 440civic said and broke it in with just the outer springs and then added the inners. It's 140 on the seat and 440 over the nose, .672 lift with 1.6 rockers. That's more pressure by about 110 over the nose on the cam than Hughes recommended but it would valve float past 7500, I wanted to twist this thing to 8000 so I added more valve spring. It's been in 2 different blocks with the same lifters and I still haven't had a problem. I've since gotten a roller of near identical specs for my new short block, why I'm not sure after all the hassle this has been, but this cam will still see duty when my kid puts it back together for his car.
[Re: astjp2]
#1071790
09/09/11 05:51 PM
09/09/11 05:51 PM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
Comp .588 solid in my 440.Been in at least 10 years.I adjust and check the lash about every 2 years.Just run Valvoline synthetic race oil.No additives ever.I run Kendall GT1 sometimes also.Rocky
Chrysler Firepower
[Re: therocks]
#1071791
09/09/11 07:36 PM
09/09/11 07:36 PM
Posts: 5,080 organ
maximum entropy
organ
i like flat tappets. solid or hydraulic. i've run some pretty big ones, all on the street and the strip. let's see, i've had... uh... mmm. it's been 35 years? ida know how many engines. a lot. one lobe on a .508 in a small block back in the early eighties was just starting to go away. caught it by accident doing other work. that was after a couple hundred runs and 45,000 miles. me and flat tappets get along real good.
[Re: therocks]
#1071792
09/09/11 07:39 PM
09/09/11 07:39 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
I run solids in both of my cars, just broke in my Hughes cam with other spring only with there additive and Mobil diesel oil.
Runs great
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
