sb cam selection #1071526
09/08/11 07:08 PM
09/08/11 07:08 PM
New Zealand
hemi o Offline OP
hemi o  Offline OP
New Zealand
right need some advice on a good cam,70 charger,auto,360 rhs heads,rpm manifold,holly 600,headmen headers,2 1/2 exhaust,3.54 diff.
Mainly street driven,thanks.
Re: sb cam selection [Re: hemi o] #1071527
09/08/11 08:07 PM
09/08/11 08:07 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
It depends on what you want to do with the car. If it was mine I would look for a hydraulic flat tappet around or below .5" lift and 220-240 degrees @.050 with an lsa not less than 110.
I am far from an expert- if you're serious about getting the most from your combo call a good cam grinder.
Also think about what kind of torque converter you will need to run to match the cam and think about matching the cam to your compression too. Don't go too radical with the duration and 3.55 gears.
Re: sb cam selection [Re: hemi o] #1071528
09/09/11 09:28 AM
09/09/11 09:28 AM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
Comp XE268 is a good one. Sounds nice, makes good power, no problems in my 360 with A/C, Auto, and 175k converter. It'll like that 3.54 gear too.
Re: sb cam selection [Re: Mapandjlp] #1071529
09/09/11 05:39 PM
09/09/11 05:39 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Voodoo 268 grind, Lunati #60403.
Comp XE268 or 274H are good as well.
