Re: Help.....Lexan windshield install.
[Re: 408strokerdart]
#1071425
09/08/11 03:36 PM
09/08/11 03:36 PM
Posts: 1,019 Finland
mafo
Finland
I have mine in the factory gasket, no glue, no problems so far
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#1071426
09/08/11 05:11 PM
09/08/11 05:11 PM
Posts: 3,456 Out West
408strokerdart
Out West
That's one with no issues....thanks for the response.
#1071427
09/08/11 05:27 PM
09/08/11 05:27 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
The fitment good on the proglass? I was going to place an order with them but have never heard anything about them, just horror storys about percys speed glass.
One day I will have something cool here.
[Re: sdaurity]
#1071428
09/09/11 12:40 AM
09/09/11 12:40 AM
408strokerdart
Out West
Well, the windshield comes slightly oversize so it needed to be trimmed. I used the original glass as a template and left it just a small bit oversized.
[Re: THE GLASS MAN]
#1071431
09/09/11 09:30 AM
09/09/11 09:30 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
as long as its factory dimensions...it should be fine.. Sans. water comming in every time you wash it.lol..
chepast
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: Scamp408]
#1071436
09/10/11 05:03 PM
09/10/11 05:03 PM
408strokerdart
Out West
What did they get you on that $$ did you use a new gasket?
Proglass wasn't cheap, but is the way to go if using stock gasket. I reused the gasket I had since it was only a couple of years old.
[Re: dvw]
#1071437
09/10/11 05:20 PM
09/10/11 05:20 PM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
Larry, did you form your windshield or is it flat? If so how did you bend it to fit it in? Doug
I had 2 professional glass men come over this morning to put it in . Had the thing almost in and decided the the glass was cut wrong. I have to do some trimming on the lower drivers side corner. As for bending it, no problem. I may have to use a inside brace, but thats required at Bonniville, I believe.
