Edelbrock Thunder 800 AVS secondary air door #1071343
09/08/11 12:14 PM
09/08/11 12:14 PM
leawood, ks
johnv Offline OP
johnv  Offline OP
leawood, ks
I hooked a vacuum gauge up last night, and I was showing 5" vacuum at WOT pretty steady from 3000 to 5500 rpm.
I was thinking it should be lower than that and maybe the air door should be further open.
I can't find much in the carb owners manual on the subject, has anyone done this before?
Thanks in advance,
John
Re: Edelbrock Thunder 800 AVS secondary air door [Re: johnv] #1071344
09/08/11 01:55 PM
09/08/11 01:55 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
is there a spring on the secondary door you can adjust? like the old AVS carb.
Re: Edelbrock Thunder 800 AVS secondary air door [Re: gtsdude] #1071345
09/08/11 04:16 PM
09/08/11 04:16 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
On the Thunder Series there is a screw on the side of the secondary door that you can turn to lighten up the spring to have it open faster and further.
