Valve springs #1070135
09/06/11 02:23 AM
09/06/11 02:23 AM
CA
mojavered Offline OP
CA
Can valve springs be changed while heads are on engine in the car? Just curious.
71 Challenger RT
440 / 727 / 8.75
Re: Valve springs [Re: mojavered] #1070136
09/06/11 03:39 AM
09/06/11 03:39 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Sure, just make sure you don't drop the valves into the cylinders. S/F.....Ken M
Re: Valve springs [Re: mojavered] #1070137
09/06/11 07:40 AM
09/06/11 07:40 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you sure can. there's 2 types of tools for doing the job & there's a proper proceedure to follow to prevent screw ups. i've just had mine off to check spring pressures, sure beats all the cleaning of gasket surfaces if you had to pull the heads.
Re: Valve springs [Re: rebel] #1070138
09/06/11 10:32 AM
09/06/11 10:32 AM
CA
CA
Thanks, That is what I want to eliminate. What is the "correct" tool to use?
71 Challenger RT
440 / 727 / 8.75
Re: Valve springs [Re: mojavered] #1070139
09/06/11 11:47 AM
09/06/11 11:47 AM
Az
Crizila Offline
Crizila  Offline
Az
You will need a tool to pump air in to the combustion chamber to keep the valves closed. I use the hose from my compression tester after removing the schrader valve from the spark plug end. I plug in the other end ( gauge end )in to shop air. The spring compressor in the pic is for stud mounted rockers. There is a similar tool for shaft mounted rockers. You can do one cylinder at a time ( intake and exhaust ) by setting that cylinder at TDC on the compression stroke. Once you have the cylinder you are working on at TDC and aired up, you will want to smack the valve spring retainers with a soft mallet ( rubber / plastic ) to loosen the keepers before you compress the springs.
Fastest 300
Re: Valve springs [Re: Crizila] #1070140
09/06/11 11:54 AM
09/06/11 11:54 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought this tool from Mancini and it works great. Just bolt it to the head by the rocker shaft bolt holes and then after you put air in the cyl you just screw the allen head bolt to push the spring down and remove the locks. Ron
Re: Valve springs [Re: 383man] #1070141
09/06/11 11:55 AM
09/06/11 11:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is another pic of it. You can do 2 valves (one cyl) before you have to move it to the next cyl. Ron
Re: Valve springs [Re: mojavered] #1070142
09/06/11 02:38 PM
09/06/11 02:38 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
http://chucker54.stores.yahoo.net/vaspreto.html
one on right works fine.
always do it with piston up whack valve spring retainer with plastic hammer to lossen keepers!
Re: Valve springs [Re: mojavered] #1070143
09/06/11 02:53 PM
09/06/11 02:53 PM
Comp Cams sells a kit that works very well on Mopar motors, LA and RB,B motors The BB part # is 5324 and part # 5323 for SB LA and V6 motors I have both and have used both of them, way better than the old lisle screw type compressors
Re: Valve springs [Re: Cab_Burge] #1070144
09/23/11 08:20 PM
09/23/11 08:20 PM
CA
CA
Thanks for all the part numbers!
Now, is there a way to know if the springs are not right for your setup?
71 Challenger RT
440 / 727 / 8.75
Re: Valve springs [Re: mojavered] #1070145
09/23/11 08:29 PM
09/23/11 08:29 PM
Absolutely, you will need a valve spring pressure tool to measure the pressures and some measuring tools to see what the installed hieght is and how much valve spring pressure you have on the seat and how much with the valves opened all the way and how much clearance you have between the valve retainers and valve seals and how close to coil bind you end up with the valves opened up all the way, nothing to it ONCE you've done it several times Now get to work
Re: Valve springs [Re: Cab_Burge] #1070146
09/24/11 10:48 AM
09/24/11 10:48 AM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
Anyone got some recommendations for a similar valve spring tool for 2G Hemi's?
Scott
