Page 1 of 4 1 2 3 4
#6/#5 spun rod bearing ? #1069256
09/04/11 08:19 PM
09/04/11 08:19 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Maybe this is old news and I didn't get the memo, but why is it that these rod bearings,especially #6, are the first to spin on a big block? Also, is there a remedy to fix this issue?
Thanks for any good input.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: #6/#5 spun rod bearing ? [Re: 68LAR] #1069257
09/04/11 08:58 PM
09/04/11 08:58 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I'd like to know too. LOL.
Re: #6/#5 spun rod bearing ? [Re: 68LAR] #1069258
09/04/11 09:29 PM
09/04/11 09:29 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I believe those are the journals that also feed the top end. Someone correct me if I'm wrong. I've heard of people drilling through the top end oil galley directly into the oil galley that feeds the mains, installing a restrictor in the hole between the galleys and a plug on the outside. Also heard of folks restricting oil to the top end. Which you can get away with with a good rocker setup, but I wouldn't try it on anything stock. Although, less oil to the top means less oil to cool the springs, which means less spring life.
Re: #6/#5 spun rod bearing ? [Re: dodgeboy11] #1069259
09/04/11 10:36 PM
09/04/11 10:36 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Thats the rods I smoked, when the engine run low of oil, before I knowned to put oil restrictors in the oil lines up top.
HV oil Pump + Stock Oil pan + Indy heads turning 6800 rpms + spin bearings!
Re: #6/#5 spun rod bearing ? [Re: 68LAR] #1069260
09/04/11 11:33 PM
09/04/11 11:33 PM
ill
dennismopar73 Offline
ill
what we do is drill hole on back side of oil pump oppisite of the oil filter,put in brake adaptor, run a 3/8 line to back of block where oil sending unit is that will help oil those bearings,,
Re: #6/#5 spun rod bearing ? [Re: 68LAR] #1069261
09/04/11 11:46 PM
09/04/11 11:46 PM
Are you using full groove main bearings or stock? If stock maybe you should use full groove instead What weight oil and what where you doing when it spun, cold , hot, driving at normal RPM or revving the motor up? Do you know how much actual (measured with micrometers and or dial bore gauge)clearance you had on the rod to crankshaft? Bearings spin for several different reasons
Re: #6/#5 spun rod bearing ? [Re: Cab_Burge] #1069262
09/05/11 09:59 AM
09/05/11 09:59 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Let me see if I can answer all of your questions:
I've used nothing but full groove mains.
I run 9 qts of 15w 40 Rotilla T with 3 bottles of STP.
Driving normal when I started hearing the rap, but don't know when it actually spun. Oil pressure with the rap was at 65 and steady????
Actuall clearance on rod bearings was .0025", mains .0025" also.
Re: #6/#5 spun rod bearing ? [Re: 68LAR] #1069263
09/05/11 10:29 AM
09/05/11 10:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On a BB isnt that the farthest point away from the
pump... what type of lifters/upper oiling and rockers
Re: #6/#5 spun rod bearing ? [Re: 68LAR] #1069264
09/05/11 10:41 AM
09/05/11 10:41 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Bearings don't spin for without reason. Somewhere, somehow the bearing came in contact with the crank. Trouble shooting the cause takes some detective work. Lack of oil,detonation, aerated oil,wrong clearances, hydrauliced cylinder ,big end distortion of the rod,poor pan design. Plenty of 440 motors around running over 7000 RPM that haven't spun bearings. I would look very carefully during dis-assembly. A very knowledgeable engine builder made this statement. If your engine has to much bearing clearance you will know it. If it doesn't have enough ,everyone will know. Good luck on your diagnosis.
Doug
Re: #6/#5 spun rod bearing ? [Re: 68LAR] #1069265
09/05/11 10:55 AM
09/05/11 10:55 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Wow, three bottles of STP . Is that the super thick STP? I run Hughes oil additive in my Rotella, two years so far with no issues.
Re: #6/#5 spun rod bearing ? [Re: justinp61] #1069266
09/05/11 11:11 AM
09/05/11 11:11 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
One bottle of STP treats 5 qts. of oil. My system, 7 Qt. pan, windage tray =1 more qt. and an
HP oil filter = 1 more qt. That's 9 qts, and I just add another bottle for GP's. You can't have too much zinc.
I run a solid lifter cam, with 1.6 roller rockers.
I agree that something had to cause the bearing to spin, my question was, why does it usually happen to #6 or #5 rod, mostly #6? And what can be done to prevent it in the future?
Re: #6/#5 spun rod bearing ? [Re: dvw] #1069267
09/05/11 11:14 AM
09/05/11 11:14 AM
NC
440Jim Offline
440Jim  Offline
NC
Doug
Common causes are loss of oil (various reasons) and detonation beating the bearing up.
Re: #6/#5 spun rod bearing ? [Re: 68LAR] #1069268
09/05/11 11:18 AM
09/05/11 11:18 AM
NC
440Jim Offline
440Jim  Offline
NC
I am not saying STP is bad, but remember that the oil in the STP bottle that carries the additives may not be the best oil. IMO, the ZDDP additives on the market now in smaller containers (4oz) are a better alternative.
http://www.zddplus.com/
Re: #6/#5 spun rod bearing ? [Re: 440Jim] #1069269
09/05/11 11:27 AM
09/05/11 11:27 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I've been using STP for 40 years. I'll probably keep using it. Here's the thing. When I pulled my engine appart, the other 6 rod bearings looked like I just put them in. Same with the mains. There wasn't any bearing left in #6 rod, and #5 looked pretty bad. This engine was assembled by me in 2004......... Again, my question is, why mostly #6 or #5 rod bearing?
Re: #6/#5 spun rod bearing ? [Re: 440Jim] #1069270
09/05/11 11:28 AM
09/05/11 11:28 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Your HP computed from your vehicle ET is 483.36 rear wheel HP and 537.06 flywheel HP.
Your HP computed from your vehicle MPH is 500.81 rear wheel HP and 556.46 flywheel HP.
Running a 4 speed and launching at that weight to run those times takes a beating. You really need to do some deep checking to see if you have a main cap issue, thrust bearing clearence incorrect or bent crankshaft. Other issues can also cause your dilema.
Just noticed you say engine has been together for 7 yrs. Did you do any anual inspections? If it went 7yrs of racing on the same build without checking the bottom end, then you actually did very excellent. Parts do go bad after abuse
Re: #6/#5 spun rod bearing ? [Re: Mopar-Al] #1069271
09/05/11 11:47 AM
09/05/11 11:47 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I can't truthfully say that I would pull the bottom end appart for inspection each year, because I didn't. I would pull the clutch and transmission down for inspection. I guess that from now on, pulling the engine's bottom end down will be a yearly thing also.
Re: #6/#5 spun rod bearing ? [Re: 68LAR] #1069272
09/05/11 11:54 AM
09/05/11 11:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How many miles on it then how many passes
Re: #6/#5 spun rod bearing ? [Re: MR_P_BODY] #1069273
09/05/11 12:01 PM
09/05/11 12:01 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Just a guess, based on approximately 1500 miles a year with usually 4 trips to the track thrown in, something less than 11,000 miles, with more than 140 passes. All just guesses, nothing documented.
Re: #6/#5 spun rod bearing ? [Re: Mopar-Al] #1069274
09/05/11 12:04 PM
09/05/11 12:04 PM
gregsdart Offline
gregsdart  Offline
Too little flow left over at # 4 to feed the rods enough. Doesn't matter what the gauge says, if it is leaving the main bearing so fast there isn't enough to feed the rods, they starve. I would restrict the passage to the rocker shafts, or feed them externally to keep max oil to #4 main. Also while the motor is down, check clearances on the lifter bores and lifters themselves and any other place oil can bleed off (cam bearings?)due to wear.
Re: #6/#5 spun rod bearing ? [Re: gregsdart] #1069275
09/05/11 12:13 PM
09/05/11 12:13 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I would restrict the passage to the rocker shafts,...
Could you plese explain how to do this? I'd appreciate it.
Thanks,
Larry
Page 1 of 4 1 2 3 4
