stock mopar alternator sqaure back style
#1069067
09/04/11 02:18 PM
09/04/11 02:18 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
How much amp load can they take? I'm thinking of a serious fan set up for my RC for towing. This one to be exact. dual fan with shroudI'm already running MAD 8 gauge tough wire threw the harness, so...............
Moparlee
Re: stock mopar alternator sqaure back style
[Re: Robbins]
#1069068
09/04/11 02:25 PM
09/04/11 02:25 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
anything betwen 50 and 78 amps depending of specific piece. hard to say. Better take it to a shop and test it.
[Re: Robbins]
#1069069
09/04/11 04:03 PM
09/04/11 04:03 PM
RapidRobert
I'd try a 78 amp alt for iirc an 85?? M body. W the add ons on the alt side w relays/all connections esp bulkhead cleaned/checked 4 voltage drops & 2 main in/out bulkhead brass terminals bypassed W Nacho's parallel bypass (easy/takes 2 wires)
[Re: Robbins]
#1069071
09/04/11 07:22 PM
09/04/11 07:22 PM
Posts: 1,822 Colorado
denfireguy
Colorado
If you want to keep the stock look, you can put a new stator into the alternator to boost its output current. 105 amps is possible. http://store.alternatorparts.com/partnoho-7014.aspx Whoops, that is for the old round back. But it does have the picture. The one you want to use is the: http://store.alternatorparts.com/partnoho-7015.aspx I have used this company for diode packs, brushes and bearings. They sell good quality products. That said, I have not done their high amp conversion. I have usually been able to find cop car alternators to salvage the stators out of. I have never needed more than 65 amps. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: NachoRT74]
#1069075
09/04/11 11:57 PM
09/04/11 11:57 PM
Robbins
Joplin, MO USA
Thanks guys, I'm playing with those clutch fans now. I've contacted a guy here on Moparts about one of his seven blade fans. I'm running a server duty thermal clutch fan now on the five blade, and really didn't see a difference.
I've got another thread on this with the clutch fans and post my questions in that thread. Learning here, please bare with me. I'm so used to running a direct fans, being the flex fans factory and non factory.
Moparlee
