Front Disc Brake Swap 78 Aspen to 68 Dart #106902
08/18/08 03:46 PM
08/18/08 03:46 PM
TX
68 Dart GTS Offline OP
TX
I have a 68 Dart with stock small bolt pattern drums on it. I have found a F-body 78 Aspen with a disc. brake system. I would like to put on the dart but not sure if it will work. Any help are suggestions would be appreciated. Thanks.
Re: Front Disc Brake Swap 78 Aspen to 68 Dart [Re: 68 Dart GTS] #106903
08/18/08 03:53 PM
08/18/08 03:53 PM
AndyF Offline
AndyF  Offline
It will work. You just need to also find a 1973 or newer A body and then you'll have all the parts you need.
Re: Front Disc Brake Swap 78 Aspen to 68 Dart [Re: AndyF] #106904
08/18/08 04:16 PM
08/18/08 04:16 PM
TX
TX
what do i need from a 73 or newer a-body for the conversion of the 78 Aspen system to the 68 dart?
Our is it a clean swap, all break system parts from the Aspen directly to the Dart.
Re: Front Disc Brake Swap 78 Aspen to 68 Dart [Re: 68 Dart GTS] #106905
08/18/08 04:25 PM
08/18/08 04:25 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
You need the upper arms off a 73-76 A body. The aspen arms won't work.
The rest of the stuff will bolt up, but, there's an argument about spindle height differences. I've run both 73-76 A spindles and the later FMJ spindles without issue.
Re: Front Disc Brake Swap 78 Aspen to 68 Dart [Re: RobX4406] #106906
08/18/08 07:46 PM
08/18/08 07:46 PM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: Front Disc Brake Swap 78 Aspen to 68 Dart [Re: RobX4406] #106907
08/18/08 08:35 PM
08/18/08 08:35 PM
TX
TX
Thanks for the help.
Re: Front Disc Brake Swap 78 Aspen to 68 Dart [Re: 68 Dart GTS] #106908
08/18/08 10:15 PM
08/18/08 10:15 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'm using 5th avenue spindles, which I think are similar to those you've got there, on a 67 dart. Drives fine, aligned at home. Aside from the A arms, you have to buy strong bolts+nuts for the spindles.
