Re: help cooling 440 dart
[Re: mopower440]
#1068919
09/04/11 03:42 PM
09/04/11 03:42 PM
RapidRobert
If your crank pulley is 7.25" your 20% overdriven right now & you're good there
[Re: RapidRobert]
#1068920
09/04/11 05:58 PM
09/04/11 05:58 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
What is your engine combo? Timing at idle, etc?
Which pump are you running and which housing?
383, Hemi 4-Speed, AlterKtion, D60
[Re: mikemee1331]
#1068928
09/05/11 01:26 AM
09/05/11 01:26 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
you can flow the coolant to the radiator as fast as you want but if it doesn't have the capacity to cool it whats the point. a 22 inch 2 row radiator is not going to cool a big block engine especially when it's hot out. take your radiator to a radiator to a shop and have it re-cored to at least 3 rows.
My 383 '70 Valiant did fine (steady 180-185 under all conditions) with a 22" 3-core with a flex fan, although it was a 4-speed so no trans cooler, and no a/c or power-anything. When I tried the same rad with a 6-71 blown 440, it wasn't near big enough even at highway speeds, let alone in traffic.
[Re: ahy]
#1068930
09/05/11 11:19 AM
09/05/11 11:19 AM
Challenger 1
Cincinnati, Ohio
You have a decent fan and shroud. The WP and fan is turning fast enough.
Respectfully disagree, a flex fan sucks and causes the problems your having.
I also think with the right tuneup the radiator you have now will do the job, well enough.
