ORIGINAL 70CUDA ROCKER MLDG SCREW PHOTO NEEDED #106840
08/18/08 01:04 PM
08/18/08 01:04 PM
boogie down bronx, ny
stevenjuliano Offline OP
HI GUYS....I don't own any 1970 cuda survivors to look at. My current project had an asst of screws holding the rocker mldgs on and I am not sure which is correct. Do any of you have a photo you can share of what an ORIGINAL screw looks like. As always THANK YOU for contributing to this insanity. Steven
Re: ORIGINAL 70CUDA ROCKER MLDG SCREW PHOTO NEEDED [Re: stevenjuliano] #106841
08/18/08 03:55 PM
08/18/08 03:55 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hi Steven, ...I saved a pic of some NOS screws a member posted a while back when this subject came up previously(I was looking for the correct pieces also}...This should point you in the right direction if you have some of your original fasteners... Colin
Re: ORIGINAL 70CUDA ROCKER MLDG SCREW PHOTO NEEDED [Re: screamindriver] #106842
08/18/08 06:42 PM
08/18/08 06:42 PM
thank you Colin of harrisburg. i believe i do have some of those. i am confident not enough. WOW the repops i've seen ain't close. then again most reproduction ive seen is worth less than the box it shipped in. again, thanks.
Re: ORIGINAL 70CUDA ROCKER MLDG SCREW PHOTO NEEDED [Re: stevenjuliano] #106843
08/18/08 07:40 PM
08/18/08 07:40 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Steven: You have a PM.
