727 wont shift out of 1st #1067918
09/02/11 10:45 PM
09/02/11 10:45 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
I just got my car put back together after I had it sitting entirely too long. The transmission was rebuilt then sat for about 3 years or so. Now I have put all new fluid in it, and it will not shift out of 1st gear. Even manually I cannot make it shift. I'm thinking that the governor may have varnished up? Does anybody have any ideas how to check/repair this, preferably without taking out the valve body if at all possible.
Thanks!
Russ
Re: 727 wont shift out of 1st [Re: moparguy] #1067919
09/02/11 11:32 PM
09/02/11 11:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How is the kickdown set up?
Re: 727 wont shift out of 1st [Re: stumpy] #1067920
09/02/11 11:36 PM
09/02/11 11:36 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
its a lokar kickdown cable setup, and I believe it is set up correctly, hard to tell with the incredibly terrible instructions received with it though.
Re: 727 wont shift out of 1st [Re: moparguy] #1067921
09/03/11 12:09 AM
09/03/11 12:09 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Eaiest way is to have the trans lever all the way back at full throttle.Then slack it off until you are happy with the shift points. I've had no trouble at all following lokars instructions.
Re: 727 wont shift out of 1st [Re: moparguy] #1067922
09/03/11 01:06 AM
09/03/11 01:06 AM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
QUICK suggestion ... disconnect it from the trans lever .. tie it back half way and try a quick 1/3 or 1/2 throttle shot.
Re: 727 wont shift out of 1st [Re: moparguy] #1067923
09/03/11 10:49 AM
09/03/11 10:49 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If you just set it up by the incredibly terrible instructions and you didn't end up doing any modifications to the attachment point of the cable at the trans end then it is anything BUT set up correctly .
To figure out if the lokar is the issue disconnect it at the trans end and go for a short easy drive, if it shifts you have found the problem.
Re: 727 wont shift out of 1st [Re: moparguy] #1067924
09/03/11 06:54 PM
09/03/11 06:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Welcome to the not-very-exclusive club of Lokar victims.....adjusting the cable so that the lever is full back at WOT is the best way to guarantee late or no light throttle upshifts.
