Who do all these modern flat Hyd sound like crap? #1067872
09/02/11 10:28 PM
09/02/11 10:28 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
I have had several of these new style Hyd flat tappet cams, sure they run OK but the valve train noise is horrible...
I know they recommend adjustable valve train in most case's but this doesnt help.. FACT..
Simply put, take a stock low mile engine with ZERO valve train noise add some old Ductile Iron Isky rockers and you now have a cam that sounds like s solid lift version...
Most shrug the noise off with a answer "Its the nature of these Cams"
Bull crap..
Or
"all these large cams do that"
Bull..
The last MP 509 Hyd cam I installed on a 493 RB engine with Edelbrock heads was quite as a mouse.
Problem is this cam I put in the car, sounds worse than a MP 590 cam with .035 inch lash LOL.
So what gives? why do these cams do this? I have had 3-4 cams do this in the past 10 years... Three have been COMP Cams, One was a Lunati bracket Master from personal experience..
Re: Who do all these modern flat Hyd sound like crap? [Re: Bob_Coomer] #1067873
09/02/11 10:48 PM
09/02/11 10:48 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
My hyd did the same thing. I figured if you can't beat em join em so I am putting a solid in my new motor!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: Who do all these modern flat Hyd sound like crap? [Re: 451Guy] #1067874
09/02/11 11:04 PM
09/02/11 11:04 PM
Rock Springs
Rock Springs
Re: Who do all these modern flat Hyd sound like crap? [Re: Bob_Coomer] #1067875
09/02/11 11:29 PM
09/02/11 11:29 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Fast rate of lift camshafts and too much spring pressure will overide the hydraulic mechanism.
Some of the cheaper lifters can't handle it.
Keith
Re: Who do all these modern flat Hyd sound like crap? [Re: Bob_Coomer] #1067876
09/02/11 11:36 PM
09/02/11 11:36 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
There are good hyd cams that are quiet,but I've seen (or heard!) a lot of hyd cams that make a lot of noise and often have issues before they get to 6000 rpm's without spending more $$$ and time than any hyd cam should receive. Why anyone would grind them is anyone's guess,but my is the cam grinders have realized the public will buy what looks good(aggressive on paper) whether it works in an engine or not. There is MUCH more to a cam than what can be seen in the lobe charts and the few reference points given by the maker(often not accurate either). Most of the noise complaints are caused by the closing ramp(or lack of),but that doesn't show up in the lobe specs.
Re: Who do all these modern flat Hyd sound like crap? [Re: Dunnuck Racing] #1067877
09/03/11 12:44 AM
09/03/11 12:44 AM
Az
Crizila Offline
Crizila  Offline
Az
Keith
That, and of course the less preload you run the noisier they will be. The install instructions that come with Hughes cams even mentions the increase in noise level with the decrease in preload. I run a pretty hefty hyd ( .615 lift ) in my 408 and I run 1/4 turn preload - and it is noisey. At 3/4 turn, it becomes quiet.
Fastest 300
Re: Who do all these modern flat Hyd sound like crap? [Re: Bob_Coomer] #1067878
09/03/11 07:47 AM
09/03/11 07:47 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
And I thought it was just me.
Makes me feel better about my last build. Thanks.
Re: Who do all these modern flat Hyd sound like crap? [Re: Dunnuck Racing] #1067879
09/03/11 10:48 AM
09/03/11 10:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Keith
This and everyone that I know wants something that will
be fast in the engine so they go with the bigger
lifts and of course they want they want the maintenance
free of the hyd cam when in reality they should have
gone with the flat tappet
Re: Who do all these modern flat Hyd sound like crap? [Re: MR_P_BODY] #1067880
09/03/11 10:55 AM
09/03/11 10:55 AM
Get-X Offline
Get-X  Offline
Keith
I couldn't agree more. IMO if you're going bigger than low .500's in lift, a solid lifter cam is the way to go. They make more power than juice cams and really aren't a lot more maintenance.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Who do all these modern flat Hyd sound like crap? [Re: Get-X] #1067881
09/03/11 12:39 PM
09/03/11 12:39 PM
Lehigh Acres, Florida
rickstershemi Offline
Our new Erson 420621 in the 408" is quiet as a church mouse
Rickster
Re: Who do all these modern flat Hyd sound like crap? [Re: rickstershemi] #1067882
09/03/11 01:24 PM
09/03/11 01:24 PM
Rock Springs
Rock Springs
How do the older MP cams differ? Wish I had my old 528 solid cam laying around, pretty much gave it away figured I would never use that ole thing...
That ole 528 solid is one heck of a street cam...
Re: Who do all these modern flat Hyd sound like crap? [Re: Bob_Coomer] #1067883
09/03/11 01:29 PM
09/03/11 01:29 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Higher idle speed
Higher viscosity
Higher low speed pressure (pump size?)
Boffin Emeritus
Re: Who do all these modern flat Hyd sound like crap? [Re: polyspheric] #1067884
09/03/11 01:40 PM
09/03/11 01:40 PM
Rock Springs
Rock Springs
I used the matching lifters from Comp, the cup seat looks to be about .100 shorter than the cam and lifters that cam out of it..
I thought about pulling the intake and throw these lifters in.. just to see.
Re: Who do all these modern flat Hyd sound like crap? [Re: Bob_Coomer] #1067885
09/03/11 01:46 PM
09/03/11 01:46 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I've been using Comp's XE295HL cam (and the Pro Magnum lifters) for over two years now and I've got lots of lifter noise. I've checked and rechecked the preload, and everything is set right. The engine runs well, but the cam/lifters are loud (especially when cold). I thought that the new HS rockers I've added might help a little, but no dice.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Who do all these modern flat Hyd sound like crap? [Re: 1968RR] #1067886
09/03/11 01:54 PM
09/03/11 01:54 PM
Rock Springs
Rock Springs
Its aggravating me... I think its Unacceptable..
The Ford and Chevy guys dont have this problem. Im sorry Id give up a little power not to hear that noise... [Edited by Moparts - Family Friendly Site - Keep it clean]?
Re: Who do all these modern flat Hyd sound like crap? [Re: Bob_Coomer] #1067887
09/03/11 02:47 PM
09/03/11 02:47 PM
Mississauga, On.
Duster 371 Offline
Duster 371  Offline
Mississauga, On.
Bob... I couldn't agree more.
But its not the the Mopar cams, installed an extremely mild
Comp Cam in my Big Block Vette and the valve train was so
noisy, i thought the lifters were bad. So after another set
of new lifters and multiple adjustments....same crap!
Re: Who do all these modern flat Hyd sound like crap? [Re: Duster 371] #1067888
09/03/11 02:56 PM
09/03/11 02:56 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
+1. I have a Comp 268H in a +.030 BBC, that not only is noisy, it's a stone. I run the recommended Comp springs, and Delphi lifters. By the way, they are no quieter than the Comp lifters, that came with the cam.
Re: Who do all these modern flat Hyd sound like crap? [Re: Duster 371] #1067889
09/03/11 03:07 PM
09/03/11 03:07 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Your correct it's NOT limited to mopar cams. It's a potential problem with any camshaft design. The first time I ran into this was around 79/80 when a certain company released a line of cams that are still being sold today,the first batches were very annoying,but a little revamp and things were quiet again.
Re: Who do all these modern flat Hyd sound like crap? [Re: Bob_Coomer] #1067890
09/03/11 03:50 PM
09/03/11 03:50 PM
Northern Indiana
Northern Indiana
These are the reasons I don't use hydraulic roller cams either. It takes a lot of work to make one work right and with all the expense,might as well go to a solid roller.
It does not help that Mopars have heavy valvetrains and even some of the aftermarket parts are heavy too.
Keith
Re: Who do all these modern flat Hyd sound like crap? [Re: Dunnuck Racing] #1067891
09/03/11 04:05 PM
09/03/11 04:05 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
If your valves are too noisy its because your exhaust is not load enough
Bob i have a mopar .528 purple stick that i broke in but swaped out for the .590 the .528 just wasnt what i was looking for in a drag race only ap
