Re: Fuel Injection with W2 heads?
[Re: 74_360_Cuda]
#1067057
09/01/11 08:16 PM
09/01/11 08:16 PM
Posts: 12,404 Taxes & Virus's R-US, NY
Dragula
I will be putting my EZ-efi system on my 408ci +500hp W2 motor...Should be perfect for it. I currently run it on my milder 360... 360 with Air Gap: Mock up on a TR.... I cut the heat runner out from the W2 intake and welded it back up. What mopar was thinking I will never know. The carb hole was way off center as well right from the factory.
[Re: ahy]
#1067060
09/02/11 01:22 AM
09/02/11 01:22 AM
Posts: 387 Montreal PQ, Canada
74_360_Cuda
Montreal PQ, Canada
I have been doing some reading and it looks like 99% of the people are extremly happy with their EZ...
What kit would I need to buy, should I buy their master kit or go with differant fuel pump/line setup?
Should I change my sending unit i.e. for 3/8 line etc...?
I think they also have an inside the tank pump... which one is preferable?
I would need a cap to block off my mechanical fuel pump opening in the timming chain cover!
[Re: 74_360_Cuda]
#1067062
09/02/11 09:40 AM
09/02/11 09:40 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I have an old street dominator intake with no air gap under the runners so I have typical Issues with hot carburator on hot days..
I was thinking to go with the victor W2 but I am a bit tired of constantly having to re-adjust the carburator and was thinking to go fuel injection. I don't think there is any kit available for W2 heads but is it possible to modify a junior Intake to have fuel rails? If so, do you know someone who does it? BTW, My heads are ported and the intake would need some work to match..
I have noticed a proliferation of EFI kits on the market... I have a 408 that have been dynoded at 505HP... which brand/kit would you recomend?
Thanks,
ease of implementation, the FAST EZ-EFI, the throttle body system
[Re: Mopar_Rich]
#1067066
09/05/11 01:03 AM
09/05/11 01:03 AM
74_360_Cuda
Montreal PQ, Canada
I'm here - ready to help ...
Thanks, I am definetly sold to the idea of buying your EZ kit... Looks like an awsome product!
I am still concerned about the proper fuel system. I am affraid that the external pump setup will be noisy and sensistive to the amount of fuel left in the tank...
What about your in-tank pump...how easy is it to install it on a stock fuel tank and avoid the fuel migration issues...?
What about venting etc..
[Re: 74_360_Cuda]
#1067067
09/06/11 06:17 PM
09/06/11 06:17 PM
Dragula
All of that has to be well thought out or difficult to find issues can arise. My stuff is all custom so that the pick-up is never uncovered during racing or street driving until the tank is empty with specially made sump. I have two systems and both work awesome. Originally, I had a healthy pro street system, and leaving parts of that in place was a big mistake..
