Name these Mopar disk brakes... #106696
08/17/08 10:03 PM
08/17/08 10:03 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline OP
These were on our 1972 Dart. They were said to be removed from a 1969 Dodge Charger. I have no idea what they are...
The rotors are large (11.95" I believe?) and the 'dished section' (area between rotor hub section & rotor braking surface is not straight/square. It is coned out from the hub to the rotor face.
They are 5x4.5" bolt pattern.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: Name these Mopar disk brakes... [Re: daniel_depetro] #106697
08/18/08 01:07 AM
08/18/08 01:07 AM
Central Ohio
rtidd440 Offline
super street
rtidd440  Offline
super street
Central Ohio
Those look more like 70-72 stuff. IIRC 69 Charger would have been 4 piston Bendix. Hopefully someone else will chime in.
Rob 70 Swinger 340 4spd FC7 4 sale 69 Charger auto Q5 14 Challenger SRT8 Core 6spd black Deposit on Hellcat
Re: Name these Mopar disk brakes... [Re: daniel_depetro] #106698
08/18/08 01:23 AM
08/18/08 01:23 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
11.75 rotors, single piston pin style calipers, can't tell if the caliper adapter brackets are for the 11.75 rotor or the 10.87 rotor...either way they are usually combined with 73-76 A body disc brake spindles & installed on A, B & E bodies...They bolt on to a B or E body & to use them on an earlier A body all you need to change is the upper control arms to a set from a 73-76 A body with disc brakes...
