Emergency battery shut off
#1065894
08/30/11 12:51 PM
08/30/11 12:51 PM
Posts: 614 ont,canada
mopartuner
ont,canada
My car is a 65 Barracuda with a stock(ish)wiring harness and I need to hook up a battery/car shut off switch.I am using a Moroso 2 pole switch.I allready have the pos cable from the battery into one side and the main cable to the starter out the other side.What I need to know is how to hook up the alternator part of this so the car will die as soon as the switch is turned off.Can I do this with just one wire going back to the switch or do I have to run a wire back to the switch and another back to the alternator?
410 pump gas solis flat tappet cam 10.95 so far
Re: Emergency battery shut off
[Re: mopartuner]
#1065896
08/30/11 02:01 PM
08/30/11 02:01 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
You can just run the power wire straight back to the positive on the battery. You should use at least #8 wire alt to batter. Your amp gauge will no longer work so by pass it and get a volt meter! ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Dodgem]
#1065897
08/30/11 02:22 PM
08/30/11 02:22 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
and have you felt the switch after its been running for awhile...things heat up fast unless you have a switch rated for the amperage..
[Re: smokinwoody]
#1065898
08/30/11 02:35 PM
08/30/11 02:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I know mine is rated at 200 or 250 amps... you pull the starter load through it... I run the alt wire to the battery side of the master... been fine for 12 years now.... to me its the simplest way and very little to go wrong ![](/ubbthreads/images/graemlins/wave.gif)
[Re: smokinwoody]
#1065901
08/30/11 07:20 PM
08/30/11 07:20 PM
Posts: 1,377 Ohio
Todd
Ohio
this is how I've been doing mine...
Thats how I wired up mine also.
[Re: smokinwoody]
#1065902
08/30/11 08:02 PM
08/30/11 08:02 PM
MR_P_BODY
if you tie it in to the battery side of the switch, there will be constant power at the alternator...ever run across the terminal on the alternator and get a big ark? this way everything up front is completely dead... sorry Mike...I knew there was a good reason for it all...LOL.. ![](/ubbthreads/images/graemlins/thumbs.gif) Dont short it out and you wont have a problem... I didnt want any more stuff on my car that can break..... you know the old saying...KISS... thats me ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 1967dartgt]
#1065907
08/31/11 12:18 PM
08/31/11 12:18 PM
MR_P_BODY
But this way is not nhra legal must run solenoid to be legal.
Must be a NEW rule as of this year... the way I said was NHRA approved for YEARS and still passes tech at some tough tracks ![](/ubbthreads/images/graemlins/wave.gif)
[Re: RobX4406]
#1065909
08/31/11 04:03 PM
08/31/11 04:03 PM
MR_P_BODY
Ever see a car burn because of a constant hot alternator wire? I have.
The way I look at it, doing it the way woody suggest, I also use a starter solenoid, on my cars there is NOTHING hot outside a 2 foot cube in the trunk of the car when the master is thrown.
Now for the failure part of the equation I carry a jumper wire to route around the constant duty solenoid. with a failure, that makes me no worse off than the constant hot route approach. I've never had a CD relay fail, knock on wood.
The jumper would be a way to correct a failure of the solenoid .... as for a car burning.. yes but cant say it was a alt hot line that did it... mines been the same way for 12 years now and its mounted in rubber grommets Does anyone know for FACT that you need the solenoid to pass NHRA tech or is the way I have it still legal ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1065910
08/31/11 05:13 PM
08/31/11 05:13 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
I haven't seen any changes, haven't looked except in the 2011 rule book and don't recall seeing anything.
[Re: smokinwoody]
#1065912
08/31/11 06:47 PM
08/31/11 06:47 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Hey Mr p, this is how the my chassis inspector explained it to me, when you turn the car off by switch they want everything dead. I have never read it in the rule book but also have never looked and have wired my car that way with the solenoid now, used to have it the other way when he told me that.
Brett Miller W9 cnc'd heads STR Chassis fabraction
