Re: Who runs 8" wheel on front 69 B body? mine wont fit??
[Re: frank]
#1065325
08/29/11 10:03 PM
08/29/11 10:03 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
IMO a 8" wheel is to wide. a 245 on a 8" is really going to ballon the sidewalls, a 7" is better. the first size tire that I wuld put on a 8" is a 275 60 15. a spacer will help but make shure that you have enough threads on the studs. good luck..
I am truckless..
[Re: frank]
#1065327
08/29/11 11:56 PM
08/29/11 11:56 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
I'm running 8" mag 500s on the front on my 68 Charger. I had to add a.250 billet spacer to clear the ball joint,BTW running 265-50-15s for tires,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
[Re: AndyF]
#1065332
08/30/11 07:23 PM
08/30/11 07:23 PM
Posts: 2,138 tucson az
frank
tucson az
8 inch fits just fine with the correct backspacing. Tubular a-arms will also help the situation as will a low profile upper ball joint.
What is the correct back space? It certaintly isn't 4.5". I want to use these 8 inch wheels and a 245 tire
[Re: frank]
#1065333
08/31/11 01:29 AM
08/31/11 01:29 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
4 1/4".
[Re: autoxcuda]
#1065335
08/31/11 02:08 AM
08/31/11 02:08 AM
Posts: 27,474 So Cal
autoxcuda
So Cal
This is 15x8 4.5" backspace rims with 73-76 A-body spindles. Look at upper right hand corner.
[Re: autoxcuda]
#1065339
08/31/11 09:23 AM
08/31/11 09:23 AM
Pale_Roader
Swears too much
Swears too much
I've run 4.5" backspace 15x8 rallyes for years. With 73-76 A-body spindle type disk brake conversion. I'm pretty sure that 15x8 super coupe rims mentioned earlier are also 4.5" backspacing. Same backspacing as the Ramcharger 15x8 rims.
Again... for those ov you ignoring my posts because i cant spell...
4 1/4" That is 4.25 inches... that is the backspace on a 15x8 Ramcharger rim. I have one literally 10ft from my computer and measured the damn thing. That 1/4" can make all the difference. I've even had these on the front ov my Challenger. They fit with a 265/50 tire, but not with a 295. Now, if i could get a 4" backspace i could run even the 295's up front.
[Re: Pale_Roader]
#1065340
08/31/11 03:28 PM
08/31/11 03:28 PM
autoxcuda
So Cal
Are you measureing to the bead or the total outside outermost lip?
I have 15x8 rallyes with 4.5" backspacing I had made up for me. I will measure and take pics when I get home from the track.
[Re: autoxcuda]
#1065342
09/01/11 08:07 AM
09/01/11 08:07 AM
Pale_Roader
Swears too much
Swears too much
Mounting face to the outermost point ov the rim. I'd like to get some 15x8 steelies made up right now with a 4" backspace... then i could fit big bad rubber IN the wheelwells on all four in my Challenger.
