72 Demon Fender Question #1064915
08/29/11 02:53 AM
08/29/11 02:53 AM
Sorrento, BC, Canada
4speeds4me Offline OP
Did the Darts and Dart Sports from 73-76 use the same fender that the 72 Demon did, or is this going to be a 1 year only item?
Thanks.
2 Demons...no, not my kids!
Re: 72 Demon Fender Question [Re: 4speeds4me] #1064916
08/29/11 08:01 AM
08/29/11 08:01 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
73s up are different... you can use a 70 dart or 71 dart/demon but IIRC the marker lights are different...
I am truckless..
Re: 72 Demon Fender Question [Re: 4speeds4me] #1064917
08/29/11 12:56 PM
08/29/11 12:56 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
72 Dart/Demon is one year only due to the side marker light.
You can use a 70-71 if you want to deal with changing the marker location/attachment, its the only difference.
73 up is one piece and has a header panel between the front fenders, 70-72 doesnt have the header and has fender extensions.
Re: 72 Demon Fender Question [Re: nomore65BelvJim] #1064918
08/29/11 06:02 PM
08/29/11 06:02 PM
I couldn't remember if the header on the 73-76 went full width or between. That was the issue. I bought a 72 Demon but the fenders hanging off of it are 71 pieces. Being as the fenders are a one year only deal, I will likely just weld the side marker pieces from the rear quarters into the fronts when I replace the rears.
Thanks again for the help, guys.
