Re: OE radio - CD says ERR
[Re: RodStRace]
#1064679
08/28/11 09:47 PM
08/28/11 09:47 PM
Posts: 10,643 S.E.Ohio
Magnumguy
S.E.Ohio
Are they home burned CD's? Mine also has problems with homemade ones. I think it may something to do with formatting of the CD's.
I had done this some success. Keep hitting the search, but go backwards, i.e ch1, then the last one, and keep going backwards. Sometimes it works.
[Re: slantzilla]
#1064685
08/29/11 08:48 PM
08/29/11 08:48 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
You can buy used ones at the pick and pull for $40 here. Only trouble is its a crap shoot, you can't test or return the unit , one heck of a business model. I bought the CD player from a wrecked Exploder (that appeared elderly owned), and got lucky, works great in my fleet truck. I worked on another Ferd radio of the same mid-2000's vintage, CD would get stuck inside and give the ERR message. Pulled the unit out and pulled the case cover, you could see bright metal to metal wear marks on the eject mechanism. I lubed all the wear marks lightly with white grease and the unit then worked properly.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
