Best way to prime a thermoquad?
#1064629
08/28/11 08:08 PM
08/28/11 08:08 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
When the fuel has evaped out or such, whats the best way to get fuel into the bowls with out opening top or taking fuel line off.
On a holley you just put it down the bowl vent stack. On a TQ though, the three stacks don't go directly into the bowls, more like slosh pockets that are separated from the bowls.
What do you all do so you dont have to crank and crank on the motor.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Best way to prime a thermoquad?
[Re: DaytonaTurbo]
#1064631
08/28/11 10:36 PM
08/28/11 10:36 PM
Posts: 1,443 Maryland
Dads426
Maryland
Make a 2nd fuel line that is bent up so you can insert a funnel and pour gas into the carb. Needle & seat will stop fuel flow when bowls are full. Remove temporary fuel line and reinstall stock line before startup. There should be enough fuel in the bowl to allow mechanical pump to refill carb after it starts.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1064632
08/28/11 11:26 PM
08/28/11 11:26 PM
Posts: 15,487 Florida
scratchnfotraction
safest way to do it as well.
I like to use a dish soap bottle with the pull cap when primming a carb such as a holley,ez pour down the vent and more control of the gas.
much safer when dumpping it down the carb as it is cranking,you know when it kicks back and shoots flames out the carb.
safty first ![](/ubbthreads/images/graemlins/thumbs.gif)
