Re: soldering wires, what 2 use [Re: jcc] #1064113
08/28/11 03:54 PM
08/28/11 03:54 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Remember to add some flux.
Re: soldering wires, what 2 use [Re: Pntastar69] #1064114
08/28/11 03:57 PM
08/28/11 03:57 PM
RapidRobert Offline OP
I was using rosin & yes I have a tin of flux somewhere. I was surprised at the probs I was having as usually that foot long heavy duty iron handles any job though it takes forever to heat up 2 get started
Re: soldering wires, what 2 use [Re: Pntastar69] #1064115
08/28/11 06:37 PM
08/28/11 06:37 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
clean both parts to shiney, flux on both, and use the rosin core especially if it's stranded wire. you shouldn't need any more high powered than your handy-dandy torch or a good heating iron.
Re: soldering wires, what 2 use [Re: RapidRobert] #1064116
08/28/11 07:51 PM
08/28/11 07:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It's possible your tip is contaminated, sand it all the way down and re tin.
I have never used flux when soldering wires, not saying it's wrong.
This one has a hi and low depending on how far you pull the trigger. Radio shack special,150/230 watts, the solder comes in different diameters and say rosin core solder on the roll.
Now I think it's different than the solder I have to solder copper pipes?
I worked for 8 years at a scale company. One of my jobs was to replace 16 pin IC chips in digital display boards. Sometimes there was like 12 chips per board X 16 pins. That's a lot of soldering with one of these and a solder sucker.
Re: soldering wires, what 2 use [Re: Challenger 1] #1064117
08/28/11 07:57 PM
08/28/11 07:57 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
flux is more of a plumbing thing but can't hurt. it helps the solder bind with the metal. and yes, you would use a solid core with plumbing.
