nEED FUEL PUMP DRIVE BELT ASAP! #1063950
08/27/11 03:25 PM
08/27/11 03:25 PM
gregsdart Offline OP
I am at BIR in Brainerd MN and the drive belt for my injector pump is broken. Any one know where I can get a 25.5 long by 1/2 wide cog belt for a fuel injection pump? I am desperate! Why the one box with the spare belt never came with is a mystry, other than being my fault! Call if you know of a source. Thanks, Greg 763 439 2129
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: gregsdart] #1063951
08/27/11 03:28 PM
08/27/11 03:28 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Grainger?
345 Plato Blvd E Ste 120
St. Paul, MN 55107-1228
Phone: (651) 298-9601
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: cgall] #1063952
08/27/11 04:03 PM
08/27/11 04:03 PM
tboomer Online work
tboomer  Online Work
No help to ya greg but how far away is JericoGTX..I used to have his phone#...Good luck!!
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: tboomer] #1063953
08/27/11 04:10 PM
08/27/11 04:10 PM
At the Track, BIR Belt is a 255lo50
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: gregsdart] #1063954
08/27/11 04:22 PM
08/27/11 04:22 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I sewed a belt together one time with an awl and fishing line. Not much torque on a water pump, though.
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: gregsdart] #1063955
08/27/11 04:40 PM
08/27/11 04:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure hope you find one
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: gregsdart] #1063956
08/27/11 04:45 PM
08/27/11 04:45 PM
NC
440Jim Offline
440Jim  Offline
NC
Sorry, my injection pump belt is 220XL037 (22.0").
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: 440Jim] #1063957
08/28/11 08:41 AM
08/28/11 08:41 AM
Yesterday was my lucky day. The Gopher State Timing Association team had the belt I needed! We ride today! Lookin for a fast pass, car went 8.94 at 139, surging after the 2/3 shift (belt was slipping) and shutting down at 1200 ft when it let go! Exhaust temp showed 1225, about 50 degrees more than it should for the air temp!
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: gregsdart] #1063958
08/28/11 11:26 AM
08/28/11 11:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad you found one Greg
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: MR_P_BODY] #1063959
08/28/11 02:06 PM
08/28/11 02:06 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
For future reference any national bearing & power transmission house like Applied Industrial, Motion or Kaman should stock timing belts. Grainger would be another good source.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: nEED FUEL PUMP DRIVE BELT ASAP! [Re: gregsdart] #1063960
08/28/11 11:36 PM
08/28/11 11:36 PM
tboomer Online work
tboomer  Online Work
Good to hear you found one,Greg!!
