initial timing,,,best vacuum
#1063943
08/27/11 02:46 PM
08/27/11 02:46 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
I think I have read this in the past, I know there are a lot of variables in determining best initial timing for an engine, but can I set the initial timing by getting the highest vacumme.
Is there such a thing as to much initial timing.
Thansk,
Jason
Re: initial timing,,,best vacuum
[Re: Challenger 1]
#1063945
08/27/11 03:11 PM
08/27/11 03:11 PM
Posts: 3,911 Oregon
hooziewhatsit
the 'rule of thumb' I read here is to advance the initial timing until you get the highest vacuum reading, then retard it enough to drop 1"hg. You'll have to adjust the idle speed to keep it normal while you advance/retard the timing.
It should go to 30ish degrees at max vacuum, then drop back to 10-20* after losing 1"hg.
Then, adjust your springs so the timing doesn't come on until a few hundred rpms over idle, and limit your total advance to 32ish.
[Re: Challenger 1]
#1063946
08/27/11 03:26 PM
08/27/11 03:26 PM
CUDAJAS
Yes too much intial timing will cause starting problems and will add to the total timing. So that must be limited if you add intial timing. Got to use a timing light, vacuum gauge and your ears.
Well, I certaily have all the tools, but my ears may not now what to listen for.
I was setting the timing this morning after replacing the advance springs in the dist. ( I limited the advance a while ago). I started out with initial in the mid 20s, and had great vacuum... it droped when I got the initial under 20.
Jason
