voltage output #1063570
08/26/11 10:23 PM
08/26/11 10:23 PM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
okay still having gauge problem issue. B-Body 1970 ralley dash.
key on 11.9 volts to gauge input wire. engine running 14.4 volts to gauge input wire is this normal?
Re: voltage output [Re: stateroadhog] #1063571
08/26/11 10:41 PM
08/26/11 10:41 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Sounds perfect!
Re: voltage output [Re: drew72] #1063572
08/27/11 12:31 AM
08/27/11 12:31 AM
IN
ahy Offline
ahy  Offline
IN
Sounds perfect!
That is exactly how it should act with a cool engine compartment.
A standard or standard replacement voltage regulator is temperature compensated. When the VR and engine compartment get hot, voltage with the engine running will drop a volt or so to 13.x. Also normal. This protects the battery which does not like higher voltage whn hot.
Re: voltage output [Re: ahy] #1063573
08/27/11 09:32 AM
08/27/11 09:32 AM
Owosso, Michigan
Owosso, Michigan
thanks for info one less problem eliminated
