radiator hoses #1063539
08/26/11 08:18 PM
08/26/11 08:18 PM
btomasko Offline OP
btomasko  Offline OP
How do you remove radiator hoses from a radiator, what method do you use? thanks
Re: radiator hoses [Re: btomasko] #1063540
08/26/11 08:27 PM
08/26/11 08:27 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
If they are stuck then you can cut them with a razor blade the lenght of the hose or use a 90* flat blade to go between the hose and the radiator tube. If not then just twist them gently to loosen them.
Re: radiator hoses [Re: stumpy] #1063541
08/26/11 08:36 PM
08/26/11 08:36 PM
IN
ahy Offline
ahy  Offline
IN
Cutting works great.
If you are trying to save the hose, carefully working a very small screwdriver between the hose and nipple can break the bond between the two and loosen things up. You may have to do it in several places to get it loosened up. Very careful use of channel locks to twist the hose is a last resort. To much clamp or force can hurt the radiator nipple... not to mention the hose.
Re: radiator hoses [Re: ahy] #1063542
08/27/11 10:34 AM
08/27/11 10:34 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
do this in conjuction with some wd-40,theyll come right off.
