Page 1 of 3 1 2 3
Could I please see your home made shop tools? #1063338
08/26/11 12:11 PM
08/26/11 12:11 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Always looking to make life a little easier around the garage.
Fastest 300
Re: Could I please see your home made shop tools? [Re: Crizila] #1063339
08/26/11 12:18 PM
08/26/11 12:18 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
my wife wont let me show them...
Re: Could I please see your home made shop tools? [Re: Crizila] #1063340
08/26/11 01:04 PM
08/26/11 01:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Ball joint socket.
Re: Could I please see your home made shop tools? [Re: justinp61] #1063341
08/26/11 01:04 PM
08/26/11 01:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Other side.
Re: Could I please see your home made shop tools? [Re: justinp61] #1063342
08/26/11 01:06 PM
08/26/11 01:06 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
On engine valve spring remover. I have some other stuff but don't have any photos.
Re: Could I please see your home made shop tools? [Re: justinp61] #1063343
08/26/11 01:42 PM
08/26/11 01:42 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Main cap puller and pusher
Re: Could I please see your home made shop tools? [Re: Bigcube] #1063344
08/26/11 02:28 PM
08/26/11 02:28 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Rt to Lt: Oil pump primer - on top of dist. wrench. Modified degree wheel. Carb stand ( 2 small holes on rt bottom corner are tapped for air bleeds - for drilling ). Head rotisserie stands - drilled to accomidate many different heads.
Fastest 300
Re: Could I please see your home made shop tools? [Re: Crizila] #1063345
08/26/11 08:50 PM
08/26/11 08:50 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
on left is tool made out of old rocker shaft to narrow too wide Isky rockers in a lathe. On right is stand to indicate in scattershield.
Re: Could I please see your home made shop tools? [Re: Crizila] #1063346
08/26/11 09:04 PM
08/26/11 09:04 PM
NC
440Jim Offline
440Jim  Offline
NC
I made this transmission tool. It is to compress the front clutch springs of a 727 Torqueflite so you can change the seals, springs, etc. Pretty simple, but something is needed to do it!
Re: Could I please see your home made shop tools? [Re: 440Jim] #1063347
08/26/11 10:20 PM
08/26/11 10:20 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Cool. Yes, it's near impossible without a tool.
Fastest 300
Re: Could I please see your home made shop tools? [Re: Crizila] #1063348
08/26/11 10:30 PM
08/26/11 10:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have so many home made tools I couldnt even think
how many... when I'm out there tomorrow I'll look
around... I just made a bunch of tools for my buddy
so he could build his 700R4 GM trans
Re: Could I please see your home made shop tools? [Re: Crizila] #1063349
08/27/11 12:05 AM
08/27/11 12:05 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My homemade 3rd member holder, I used it I bet 5 years. Something I threw together one night to make service easier. It works.
Then I bought a real one that holds heads and other things too.
4X4 block of wood works good to hold lifters.
I did not make this push rod holder, but my buddy did. Homemade clutch disc indicator fixture under that clutch disc.
He's very crafty.
Re: Could I please see your home made shop tools? [Re: MR_P_BODY] #1063350
08/27/11 12:14 AM
08/27/11 12:14 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
A few engine building tools: Most are obvious. Cam install tool can be used with single bolt cams ( SB as shown ) using the aluminum adaptor which has a 7/16" threaded rod on the cam side or that section can be unbolted ( 3 bolts ) and it can be used with 3 bolt cams and dowel pins. Handle is about 15" long and has a "T" on the other end ( not in pic). Angle tool on top of the block is an easy way to see if the head port side angle matches the manifold angle. Cam checking lifter is nothing more than 2 gutted hyd lifters with a piece of threaded pipe jamed between them. Adjustable positive stop on #1 hole.
Fastest 300
Re: Could I please see your home made shop tools? [Re: Crizila] #1063351
08/27/11 04:14 AM
08/27/11 04:14 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
A very handy holder for the 8.75" pig.
Re: Could I please see your home made shop tools? [Re: Mcode69] #1063352
08/27/11 04:20 AM
08/27/11 04:20 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Sorry, I haven't got any real good pics of it.
Re: Could I please see your home made shop tools? [Re: Mcode69] #1063353
08/27/11 08:12 AM
08/27/11 08:12 AM
metro detroit
turner Offline
turner  Offline
metro detroit
tubing bender for 1" black pipe or similar diameter material, bender made with scrap parts and powered by muscle...we have another at work thats gets used and abused by 60 other millwrights and works awesome
Re: Could I please see your home made shop tools? [Re: Crizila] #1063354
08/27/11 03:21 PM
08/27/11 03:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some of my homemade stuff for overhauling 727's.
Re: Could I please see your home made shop tools? [Re: John_Kunkel] #1063355
08/27/11 03:45 PM
08/27/11 03:45 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I've got pump pullers similar to yours. What's the horse-shoe looking thing for on the upper right side?
Fastest 300
Re: Could I please see your home made shop tools? [Re: Crizila] #1063356
08/27/11 03:50 PM
08/27/11 03:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I assumed it's for depressing the springs in the clutch pack so you can remove the snap ring.... Used with a press..
Re: Could I please see your home made shop tools? [Re: Crizila] #1063357
08/27/11 04:58 PM
08/27/11 04:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is my valve spring compressor(for heavy springs)
Page 1 of 3 1 2 3
