1970 Duster Antenna Bezel #1063326
08/26/11 11:33 AM
08/26/11 11:33 AM
USA
soho Offline OP
soho  Offline OP
USA
Does anyone have a picture of their original 1970 Duster Antenna Bezel installed on their cars on hand?
Does anyone have an indentation in their fender on the inner side of the bezel?
I have only seen ( and can find) fenders where the bezel sits flush on a flat fender, and the mast angle is set by a canted bezel.
Re: 1970 Duster Antenna Bezel [Re: soho] #1063327
08/28/11 09:33 PM
08/28/11 09:33 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Since there are no responses here is some info that may or may not be of help. The attached pics are of my 70 Dart Swinger (same fender as Duster I believe) I have owned since 1974. Shortly after buying it I replaced the 3 piece telescoping mast with the 1 piece style I preferred. I bought the parts from Chrysler but don't remember if I replaced everything including the bezel or just the mast and base, after all, it had been 35+ years :-).
I have heard the fenders with the indent were used in later A bodies, perhaps Scamps, and for a few years when buying from Chrysler you could get either style under the same part#.
Re: 1970 Duster Antenna Bezel [Re: soho] #1063328
08/28/11 10:33 PM
08/28/11 10:33 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I took these today of my '71 Duster. Should be the same as a '70. Any way, hope this helps.
Mike
Re: 1970 Duster Antenna Bezel [Re: soho] #1063329
08/29/11 12:21 PM
08/29/11 12:21 PM
USA
soho Offline OP
soho  Offline OP
USA
Thanks for the pictures.
You are showing what ours looks like out back, and is what we were expecting.
It turns out the guy has a Canadian fender we're told. Here is a picture of his fender using a US bezel.
Re: 1970 Duster Antenna Bezel [Re: soho] #1063330
08/29/11 08:32 PM
08/29/11 08:32 PM
Elk Grove, Calif.
Elk Grove, Calif.
Did it clear things up?
