Re: Viper eng in a street rod ???? [Re: ] #1063203
10/31/14 05:09 PM
10/31/14 05:09 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Wow, Man!!!
I HAVE to see pictures of this.
A V10 in an old Mopar................SOOO COOOL!!!
hell yeah a V10 or a hemi in an old mopar is so cool
and ANY mopar engine is too, any mopar engine is better than any non mopar
here is a 34 dodge coupe with a viper v10
Re: Viper eng in a street rod ???? [Re: ] #1063204
11/11/14 03:35 AM
11/11/14 03:35 AM
Ardrossan, Alberta, Canada
47droptop Offline
47droptop  Offline
Mudgy, there are some pics on my Facebook page (Glen Ferko)
Re: Viper eng in a street rod ???? [Re: Mopar Ron] #1063205
11/11/14 05:05 AM
11/11/14 05:05 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
Wow, Man!!!
and ANY mopar is too, any mopar is better than any non mopar
thats KOOOL...theres a red one just like that in CT with a 6 speed the tagss says old viper
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Viper eng in a street rod ???? [Re: 47droptop] #1063206
11/11/14 05:24 AM
11/11/14 05:24 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
I got the truck V10 set into my '47 Plymouth. I had to cut the firewall back a small amount, but have lots of room for a rad and A/C condensor. Not sure on the length of the viper engines, but you can make it fit fstfish66!!!
KOOOL
2015 cherokee
2013 R/T classic
Re: Viper eng in a street rod ???? [Re: 47droptop] #1063207
11/17/14 04:20 AM
11/17/14 04:20 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
47droptop-Glen,did you use the truck transmission also? I ask because I am wondering about the bellhousing bolt pattern.I have an old truck with an LA small block and was thinking about a V10 swap.
RT
Re: Viper eng in a street rod ???? [Re: RTSrunner] #1063208
11/17/14 08:45 PM
11/17/14 08:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe the V10 has a different transmission bolt pattern then a LA or a Magnum motor. I think its the same trans as a diesel uses. Gene
Re: Viper eng in a street rod ???? [Re: poorboy] #1063209
11/17/14 08:51 PM
11/17/14 08:51 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
This is correct.
There are a ton of bellhousing adapters to mate the 5.9 Cummins to Gm, Ford, and many other transmissions. They will mate to the truck V10 as well.
- Stu Harmon
Re: Viper eng in a street rod ???? [Re: feets] #1063210
11/21/14 02:20 AM
11/21/14 02:20 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
those adapters are called the flywheel/starter adapter---they bolt only to the cummins block and are about 3 inches thick---the v10 motor has the tranny bolting directly to it---no adapter....
