Why would a coil get smoking hot and stay that way? #1063135
08/26/11 01:55 AM
08/26/11 01:55 AM
Sask, Can.
72demon416 Offline OP
Sask, Can.
I'm posting this for a friend with a 71 Bee with a 383. He tells me within a couple minutes after starting the car the coil gets hot enough to burn you and won't restart if shut off. The car has electronic ignition and he has changed ignition boxes (MP orange) and ballast resistors ( Napa 2 terminal replacements- likely wrong). He has bought a new MSD coil for it but has not tried it yet and is getting all kinds of advise but the most common being poor grounds. Any ideas?- electronics problems are not my bag....
Re: Why would a coil get smoking hot and stay that way? [Re: 72demon416] #1063136
08/26/11 03:47 AM
08/26/11 03:47 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
ballast resistor is not stepping down to 6 volts after startup.
-Daty
Re: Why would a coil get smoking hot and stay that way? [Re: 72demon416] #1063137
08/26/11 07:26 AM
08/26/11 07:26 AM
Central TX
roe Offline
roe  Offline
Central TX
The Napa 2 terminal ballast may be correct, it was on my 71 Satellite. No answer for your question though, good luck. I'll be following this thread
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Why would a coil get smoking hot and stay that way? [Re: 72demon416] #1063138
08/26/11 09:52 AM
08/26/11 09:52 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
It is definitely not a poor ground. If it was poor, no current would flow and the coil would be cool. My guess, and only a guess without the coil in front of me, is shorted windings in the coil. That would allow the coil to function but the shorted windings would lower the DC resistance of the coil causing it to make more heat. It also puts an AC load on the coil so when the field collapses to fire the spark plug, it puts a damper effect on the coil, making even more heat. Try a new coil.
Craig
Re: Why would a coil get smoking hot and stay that way? [Re: 72demon416] #1063139
08/26/11 10:18 AM
08/26/11 10:18 AM
If you have a VOM check the voltages on it while running & take the wires off of it & ohm it while hot, ohm the ballast while you're at it. (1) touch each pri terminal on low ohms scale and (2)same w ballast (3)then switch to K (X1000) ohms scale & check either pri terminal and center terminal. As said ballast value too low (likely)or shorted windings (way less likely) or wrong coil 2 begin w
Re: Why would a coil get smoking hot and stay that way? [Re: RapidRobert] #1063140
08/26/11 11:59 AM
08/26/11 11:59 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
As a reference a spare coil I have measured 1.5 ohms across the primary + to -. and 10.87 K ohms from - to the (center) coil wire terminal. All this at 88 degrees F.
Ron
Re: Why would a coil get smoking hot and stay that way? [Re: Ronnman] #1063141
08/26/11 02:05 PM
08/26/11 02:05 PM
Sask, Can.
Sask, Can.
Thanks for the tips guys- I'll pass it on
Re: Why would a coil get smoking hot and stay that way? [Re: Daty Rogers] #1063142
08/26/11 08:06 PM
08/26/11 08:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
-Daty
you didn't say what type of coil but the resistor is mismatched.
Re: Why would a coil get smoking hot and stay that way? [Re: mikemee1331] #1063143
08/26/11 08:50 PM
08/26/11 08:50 PM
Sask, Can.
Sask, Can.
I believe it is just a factory coil.
Re: Why would a coil get smoking hot and stay that way? [Re: 72demon416] #1063144
08/26/11 09:29 PM
08/26/11 09:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
put in the blaster. is the ECU fairly new? if so you shouldn't need a ballast with the blaster coil. if it's an older conversion ECU you will need the ballast that came with the blaster coil.
Re: Why would a coil get smoking hot and stay that way? [Re: mikemee1331] #1063145
08/27/11 12:27 PM
08/27/11 12:27 PM
Sask, Can.
Sask, Can.
If I recall our conversation correctly he sail he had changed the ecu but it made no difference. I would have to guess it's a older conversion. So your saying to turf the ballast when he installs the msd coil?
Re: Why would a coil get smoking hot and stay that way? [Re: 72demon416] #1063146
08/27/11 01:09 PM
08/27/11 01:09 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
It's either the coil or the ballast. Check the resistance of the coil and ballast (I don't recall the specs but google does.)
If you got 6 to 9v at the coil your good buy you probably have closer to 12v meaning the ballast isnt dropping the voltage.
If the coils smokng it means it got to much voltage at the + terminal (ballast) or it's drawing too current (coil shorted)
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Why would a coil get smoking hot and stay that way? [Re: aarcuda] #1063147
08/27/11 01:54 PM
08/27/11 01:54 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Does the BEE have four wires to a double ballast . could it be one terminal is reversed ?
Re: Why would a coil get smoking hot and stay that way? [Re: 72demon416] #1063148
08/27/11 05:16 PM
08/27/11 05:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
here, read through this - https://board.moparts.org/ubbthreads/show...rue#Post6776227
Re: Why would a coil get smoking hot and stay that way? [Re: mikemee1331] #1063149
08/27/11 08:49 PM
08/27/11 08:49 PM
Under My Car
Mopar_Country Offline
Under My Car
The coil could be going bad. The ballast resistor should drop the coil run voltage to 9v. If he replaces the stock coil with a Blaster 2 then you need a .25 ohm ballast.
Re: Why would a coil get smoking hot and stay that way? [Re: Mopar_Country] #1063150
08/27/11 09:44 PM
08/27/11 09:44 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i would say you are right about the coil being bad. as to the blaster coil, he might not need a resistor. he would need to varify that with the manufacture of the ECU he is running. the blaster coil itself does not require a ballast resistor. only if running points or an older ECU.
Re: Why would a coil get smoking hot and stay that way? [Re: mikemee1331] #1063151
08/28/11 01:16 AM
08/28/11 01:16 AM
Sask, Can.
Sask, Can.
Thanks guys,
I'll have to find out a little more on his setup and get him to check his voltages at the coil.
Re: Why would a coil get smoking hot and stay that way? [Re: 72demon416] #1063152
08/28/11 11:00 AM
08/28/11 11:00 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Sorry, but I don't get to say this very often... The oil in the coil is at a broil.
Re: Why would a coil get smoking hot and stay that way? [Re: scatpacktom] #1063153
08/28/11 02:43 PM
08/28/11 02:43 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Re: Why would a coil get smoking hot and stay that way? [Re: 72demon416] #1063154
08/28/11 06:00 PM
08/28/11 06:00 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I have a friend that had this happen with a SBC in a street rod,the coil was wired wrong. I wouldn't have thought it would run but it did.
