Why would a coil get smoking hot and stay that way?
#1063135
08/26/11 01:55 AM
08/26/11 01:55 AM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
I'm posting this for a friend with a 71 Bee with a 383. He tells me within a couple minutes after starting the car the coil gets hot enough to burn you and won't restart if shut off. The car has electronic ignition and he has changed ignition boxes (MP orange) and ballast resistors ( Napa 2 terminal replacements- likely wrong). He has bought a new MSD coil for it but has not tried it yet and is getting all kinds of advise but the most common being poor grounds. Any ideas?- electronics problems are not my bag....
Re: Why would a coil get smoking hot and stay that way?
[Re: 72demon416]
#1063138
08/26/11 09:52 AM
08/26/11 09:52 AM
Posts: 1,822 Colorado
denfireguy
Colorado
It is definitely not a poor ground. If it was poor, no current would flow and the coil would be cool. My guess, and only a guess without the coil in front of me, is shorted windings in the coil. That would allow the coil to function but the shorted windings would lower the DC resistance of the coil causing it to make more heat. It also puts an AC load on the coil so when the field collapses to fire the spark plug, it puts a damper effect on the coil, making even more heat. Try a new coil. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 72demon416]
#1063139
08/26/11 10:18 AM
08/26/11 10:18 AM
RapidRobert
If you have a VOM check the voltages on it while running & take the wires off of it & ohm it while hot, ohm the ballast while you're at it. (1) touch each pri terminal on low ohms scale and (2)same w ballast (3)then switch to K (X1000) ohms scale & check either pri terminal and center terminal. As said ballast value too low (likely)or shorted windings (way less likely) or wrong coil 2 begin w
[Re: Daty Rogers]
#1063142
08/26/11 08:06 PM
08/26/11 08:06 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
ballast resistor is not stepping down to 6 volts after startup.
-Daty
you didn't say what type of coil but the resistor is mismatched.
[Re: 72demon416]
#1063146
08/27/11 01:09 PM
08/27/11 01:09 PM
Posts: 15,493 the boonies
aarcuda
the boonies
It's either the coil or the ballast. Check the resistance of the coil and ballast (I don't recall the specs but google does.)
If you got 6 to 9v at the coil your good buy you probably have closer to 12v meaning the ballast isnt dropping the voltage.
If the coils smokng it means it got to much voltage at the + terminal (ballast) or it's drawing too current (coil shorted)
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: scatpacktom]
#1063153
08/28/11 02:43 PM
08/28/11 02:43 PM
mikemee1331
bethlehem pa
Sorry, but I don't get to say this very often... The oil in the coil is at a broil.
[Re: 72demon416]
#1063154
08/28/11 06:00 PM
08/28/11 06:00 PM
Posts: 1,565 tennessee
pushbutton
tennessee
I have a friend that had this happen with a SBC in a street rod,the coil was wired wrong. I wouldn't have thought it would run but it did.
