Page 1 of 3 1 2 3
dyno results... not happy diagnosis please #1063086
08/26/11 01:11 AM
08/26/11 01:11 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi guys
I was excited last week took the car to the dyno to see what result happened from my changes to the car.
Ok here is car last year
4040 with me in it
440 40 over 9.5:1 compression ratio
440stealth heads
comp cam XE 268 degreed to 107 LSA
770 street avenger carb
street dominator intake
shorty style headers
727 2600 stall converter
3:23 gears
uncapped headers thru 2.5 inch cutouts
HP 327
Torque 404
Ok tonight
4040 with me in it
440stealth heads
comp cam XE 274 put in straight up at 110 LSa
750 Holley Double pumper 76/78
727 4200 stall converter
3:91 gears
HP 311
Torque 334!
ok, I'm down 16 HP and 70 lb of torque!
It doesn't make sense!
The car runs beautifully, pulls strong now all the way up to 5800 rpms! It is a blast to drive. It comes out of the hole like its on fire now.
Why would I be down?
Thanks for any info
Ok for the record temp and humidity for pretty similar!
Take it away fella's
Mike
1969 Dodge Dart Swinger
Re: dyno results... not happy diagnosis please [Re: MikeyT] #1063087
08/26/11 01:23 AM
08/26/11 01:23 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
did u get any afr's?
Re: dyno results... not happy diagnosis please [Re: MikeyT] #1063088
08/26/11 01:29 AM
08/26/11 01:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What changes did you make while still on the dyno
to get it to pick up
Re: dyno results... not happy diagnosis please [Re: MR_P_BODY] #1063089
08/26/11 01:50 AM
08/26/11 01:50 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Afr's were good most of pull around 12.5 and at about 5600 started to richen up a bit.
Things I did, were jet it up, up front to 76 and backed off a bit in back 78 jets, which was a 2 jet sized up and one down in back
Timing was 36 all in At 3000 rpms
Mike
Re: dyno results... not happy diagnosis please [Re: MikeyT] #1063090
08/26/11 02:11 AM
08/26/11 02:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike
Check your fuel supply that its doing proper(flow
test)... start a process of eliminations to what is
holding it back... simple things first... testing
can be fun... dont let it get you down
Re: dyno results... not happy diagnosis please [Re: MikeyT] #1063091
08/26/11 02:20 AM
08/26/11 02:20 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Loose torque converters on chassis dyno's often lead to results that don't match actual performance. A manual trans would help make the playing field more level. I assume this is the same dyno used in the previous testing? What info was the dyno operator able to give about the results?
Re: dyno results... not happy diagnosis please [Re: MikeyT] #1063092
08/26/11 02:20 AM
08/26/11 02:20 AM
Did you verify that the new carb is all the way open when the gas pedal is on the floor? Simple stuff first, then look at the tune up One other thing is "Street Avavenger 770" CFM carb versus "Holley 750" CFM D.P. carb Do you still have access to the other carb If so try it next
Re: dyno results... not happy diagnosis please [Re: MR_P_BODY] #1063093
08/26/11 02:24 AM
08/26/11 02:24 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Firstly... Bigger converters tend to soften number on wheel dynos. Lots of times cars with big converters give off weaker numbers, especially if they have a hard time calibrating the load correctly. Where was peak torque RPM wise both times?
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: dyno results... not happy diagnosis please [Re: MikeyT] #1063094
08/26/11 05:18 AM
08/26/11 05:18 AM
Australia
Charger VJ RB Offline
Australia
Don't worry about the dynos especially chassis ones they are just a tuning device for the track, run it and see what time it makes then you will know actual HP.
Re: dyno results... not happy diagnosis please [Re: Charger VJ RB] #1063095
08/26/11 07:18 AM
08/26/11 07:18 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Thanks guys! These are great ideas. To answer the question.
Torque wise it looked like converter came in at 4200 peak!
Cab great idea. I'm pretty sure it was opening all the way, but I'll check it. I do have access to the old 770 street avenger carb.
Thanks for the support. I'll look into these things and get back to you.
Mike
Re: dyno results... not happy diagnosis please [Re: Charger VJ RB] #1063096
08/26/11 08:57 AM
08/26/11 08:57 AM
NC USA
U
ultimatelenny Offline
U
NC USA
X2 Get your tune up close on the dyno then get to the track and get some real track data. The track will be the determining factor to dailing your combo in under real world conditions
Lenny Croteau www.ultimateconverter.com Phone 704-892-6837 Fax 704-892-6880
Re: dyno results... not happy diagnosis please [Re: ultimatelenny] #1063097
08/26/11 09:21 AM
08/26/11 09:21 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Two things. First I like the evenger carb. It runs real clean and has a great fuel curve. Was your cruise a/f way lean that you had to richen the primaries? If that was good I would not have richen up the primaries. Also was the dyno a dynojet type that is a fixed wieght or was it a eddy curent type? The fix wieght type are more repeatable. Also you would really need to see the acual resaults at the track. The dyno is only a tuning tool. I am surprised that the no. went down with the gear change ussaully they go up with more gear. Put the other carb on and see what happens. Jake
JAKES AUTOMOTIVE
Re: dyno results... not happy diagnosis please [Re: goldmember] #1063098
08/26/11 09:24 AM
08/26/11 09:24 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
This
Re: dyno results... not happy diagnosis please [Re: sixpackgut] #1063099
08/26/11 09:29 AM
08/26/11 09:29 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Just went back and read your post and realized that you changed converters. That is a big difference on the dyno. Also it seams to be to much converter for that combo.imo
JAKES AUTOMOTIVE
Re: dyno results... not happy diagnosis please [Re: JAKE68] #1063100
08/26/11 09:55 AM
08/26/11 09:55 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Opps sorry, it had been a long day! I had a 4200 converter, but we pulled it and had it tightened up to 3800, sorry for the confusion.
So scratch that 3800 stall, not 4200.
Mike
Re: dyno results... not happy diagnosis please [Re: MikeyT] #1063101
08/26/11 10:00 AM
08/26/11 10:00 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Seems off. Your jetting seems low for a 440. I ran a much milder 440 set up w/ a proformed main body 750DP and ran 76/84's seemed to work well. What is your timing set at? You'd probably do well with it all in full around 2400 and 38*. I take it that is rear wheel HP???
Coming soon!!!!
Re: dyno results... not happy diagnosis please [Re: Mr.Yuck] #1063102
08/26/11 03:59 PM
08/26/11 03:59 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
If your happy with its perf. who cares what ANY dyno tells you, just a waiste of $$$ IMO, I never use them & never will, just take it to the track & tune there, thats "real world".
If i had a $1.00 for everytime someone ask me how much HP i was running in my duster i'd have a pocket full of $$$ & would pay for my entry fees each time , I would always tell them "enough to run 10s" LOL, it runs good & i'm very happy with it & thats that .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: dyno results... not happy diagnosis please [Re: MikeyT] #1063103
08/26/11 05:04 PM
08/26/11 05:04 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
yes wrong cam degree move it to 105 and it will be all good!
Re: dyno results... not happy diagnosis please [Re: Dodgem] #1063104
08/26/11 05:18 PM
08/26/11 05:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Not every converter has exactly the same torque multiplication.
Testing multiple changes to the engine is fine, but the converter swap did away with any chance of comparing last week's results to the new results.
Rich H.
Esse Quam Videri
Re: dyno results... not happy diagnosis please [Re: MikeyT] #1063105
08/26/11 05:22 PM
08/26/11 05:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike
At 12.5 I would try to lean it down just a bit to
try and get 12.8 to 13.... then try it at the track
to get the best MPH on jetting
Page 1 of 3 1 2 3
