Re: Roof paint/sealer for racecar trailer.
[Re: 70satelliteguy]
#1063022
08/25/11 09:29 PM
08/25/11 09:29 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
why not? a roof has no gender maybe a new rubber roof would do the trick inexpensively
home of the Sox and Martin Hemi Duster
#1063027
08/26/11 09:31 AM
08/26/11 09:31 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Any recommendations? Trailer is 6 years old and has slight leaks here and there. Can I use mobile home roof paint/sealer? Thanks Mike
It most likely has a perimeter seal on the roof which should be scraped off, cleaned and replaced....then coat the roof with one coat of primer followed by two coats of the liquid rubber roof coating sold at RV dealers....the new rubber coating will prevent the perimeter seal from drying out or at least extend it's life and will keep the interior of the trailer much cooler
PS....they also sell roof gutters that install along the topside edge that will channel water to the rear of the trailer which aids really well in stopping black streaks down the sides of the trailer
Rickster
[Re: rickstershemi]
#1063028
08/26/11 09:41 AM
08/26/11 09:41 AM
Challenger 1
Cincinnati, Ohio
Rickster
Yes only do the seam, not the whole thing. When I wash my trailers, I start with the roof first, get it clean and the black stains stop running down the side. Bare aluminum for a roof is better than having some kind of coating up there, because it can chip off when the roof flexes and holds dirt. Don't coat the whole roof, I'm telling you.
[Re: rickstershemi]
#1063029
08/26/11 09:43 AM
08/26/11 09:43 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Rickster
What store did you see these at? Was looking to make something for this and didn't know they were available. That will definately keep the black streaks off.
Sorry for the hijack OP
[Re: roadhazard]
#1063030
08/26/11 09:46 AM
08/26/11 09:46 AM
rickstershemi
Rickster
I sourced them through a local trailer sales & supply down here in FLA.....I'm sure any large trailer dealer could source them for you
Rickster
[Re: Challenger 1]
#1063031
08/26/11 09:51 AM
08/26/11 09:51 AM
rickstershemi
Rickster
Have to disagree.....if you prepare the roof correctly to the coating manufacturer's recommended installation it will not crack or chip....it's an elastomeric product and meant to flex....also just the rubber coating by itself will greatly reduce black streaks in lieu of the bare aluminum skin
I did my 50 footer and I highly recommend it
Rickster
[Re: rickstershemi]
#1063032
08/26/11 09:56 AM
08/26/11 09:56 AM
Challenger 1
Cincinnati, Ohio
Rickster
Rickster
I keep my aluminum roof clean and have had no black stains for years now. No added weight and nothing to come off.
