Re: B body wiper linkage arms....
[Re: NachoRT74]
#1062888
08/26/11 09:54 AM
08/26/11 09:54 AM
Posts: 251 USA
ramairthree
USA
Thank you for the incredible information. This is awesome. I had gotten to the point I knew I had a two speed motor, had to get the resistor for two speeds, got that set up and working. I have the transmission arm attached to the motor and appears to work and have park function (without everthing else hooked up yet. I have one each of the transmission arms (the "6" vs "7" part number) and got to the point where I thought the only difference was the hole in the motor end of the shaft and those threads verify that. my cover boot is in rought shape also and just glad to have one. I will get more grease in there. it appears that the linkake that goes between the wiper arm pivots is the same for a two or three speed. I have some of those plastic washer/clips, so after some arm bending and swearing, should be good to good thanks to all these threads and pictures you hooked me up with here. Be glad our cowl mesh grills come off. Ever tried hooking your wiper transmission linkage arm up on a car with the ONLY access into the cowl is through the hole your wiper motor goes into? That will get you cursing on its own, then throw in a clip worse to hook up, and even a nun would be making sailors blush. Anyway, thank you again for the info and help, this nails it!
[Re: ramairthree]
#1062890
08/30/11 02:30 PM
08/30/11 02:30 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
make teh complete linkage assembly out of the car then slide into teh cowl area and fit the pivots.
the plastic bushings are REALLY HARD to fit, and even I did it, still dunno how to make it without damage them
[Re: gtx6970]
#1062892
08/30/11 03:42 PM
08/30/11 03:42 PM
NachoRT74
Valencia, España
I never could fit them nice an clean into the links they got some ugly scratches . Links also got some bends on thar area what I had to straighten out once bushings got in fit them into the studs was fairly easy . Used vaseline
[Re: ramairthree]
#1062895
08/30/11 07:44 PM
08/30/11 07:44 PM
Posts: 251 USA
ramairthree
USA
ps- I have the linkage between the wiper pivot arms installed like in this picture, am I correct or do I have it upside down? Thank you.
[Re: ramairthree]
#1062896
08/30/11 08:15 PM
08/30/11 08:15 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Somehow, that doesn't look right.
Are we looking at it from the driver's seat, so to speak?
If so, the lever arm that's on the linkage (the dogleg piece) that bolts onto the wiper motor shaft is on the wrong side of the linkage.
If we're looking at it from the the front of the car (which I suspect), shouldn't the linkage arm go to the passenger side pivot arm? I believe the linkage arm needs to be turned over, the drive lever arm needs to placed on the other side of the hole in the linkage arm, and the pivot in view (which I believe would be the passenger side pivot) needs to be the one that the two rods/linkages attach to.
Maybe I'm just not seeing something here...
[Re: ramairthree]
#1062899
08/31/11 01:03 AM
08/31/11 01:03 AM
MoparMarq
Vancouver, WA
Sorry about the earlier bad info. Just looked at my '72. Linkage from wiper drive arm to driver side pivot looks the same as mine. The cross-link (from driver-side pivot to passenger-side pivot) looks very slightly different than mine: On mine, the curved side faces forward and the sharp edges of the link face aft. In your pic, it shows the curved edge facing aft and the sharp edges facing forward. Not sure if it would make a difference, as I believe the link is straight, but I didn't feel along the full length of it. My wipers do work properly without binding, tho. I didn't look at the link full length under the cowl, but the parts catalog pic shows a curve in it. I would think, due to the curvature of the cowl, that any curve in the link would need to be forward to keep from hanging up on the back part of the cowl underneath where the window stainless trim is attached.
[Re: gtx6970]
#1062901
09/01/11 12:22 AM
09/01/11 12:22 AM
NachoRT74
Valencia, España
actually where is pointing out the link curvature shouldn't be more important than correctnes itself more than functionality... HOWEVER could it be checked just for clearence purpuse with pivot baseplate or whatever around. I can't recall how were mine, but I think pics are still with stock position. When I did it simple removed one and replace inmediatly, then the other one to be sure I was installing on same position.
