70 Challenger replacement panels, AMD or Goodmark?
#1062833
08/25/11 01:16 PM
08/25/11 01:16 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Converting a 73 Challenger w/solid frame and rusty quarters over to a 70/71.
Ready to buy Quarter skins, tail panel and new trunk lid.
Goodmark seems to be cheaper of the two and yes, i'm aware you get what you pay for. outer wheel houses are fine, just need skins.
Also, do I need the "rear panel to bumper filler" piece that I see listed for 70/71? I'm thinking yes.
All advice and pointers appreciated.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: 70 Challenger replacement panels, AMD or Goodmark?
[Re: Hoof Hearted]
#1062834
08/25/11 01:45 PM
08/25/11 01:45 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
I put a pair of Goodmark panels on my wifes Challenger,and when I pressed on the wheel lip with my palm to push the panel in and clamp it to the wheel house my plam dented the panel. That will not happen with an AMD panel. AMD uses thicker than the original guage metal. The Goodmark panels are thin and flimsy. Spend the few extra bucks and get the AMD panels. If they were available when I did her car I would have bought them and sold off the Goodmark peices.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: Strawdawg]
#1062836
08/25/11 10:05 PM
08/25/11 10:05 PM
Posts: 643 southern conn
1969gtx
southern conn
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: 1969gtx]
#1062837
08/26/11 10:44 AM
08/26/11 10:44 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I just installed the goodmarks on my cuda yesterday. the metal IS really soft. and in trying to get it to fit tight around the seams, I did get some light dimples into the metal. nothing impossible to fix, but it's just more block sanding I'll have to do.
no experience with AMD quarters though. the AMD trunk gutter piece and yes, that little filler piece, both looked great, and fit good.
**Photobucket sucks**
[Re: Hoof Hearted]
#1062838
08/26/11 11:58 AM
08/26/11 11:58 AM
Posts: 340 Alaska
73rrak
Alaska
[Re: wally426ci]
#1062840
08/26/11 01:48 PM
08/26/11 01:48 PM
chargervert
The AMD fenders are out now and available to purchase.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#1062841
08/26/11 01:51 PM
08/26/11 01:51 PM
70Cuda383
Marysville, O-H-I-O
I was gonna say, I thought I saw BOXES of Fenders at the swap meet at the Nats, Stephens performance, right across from the AMD tent with their "85% new" 71 Cuda.
guy told me that only 15% or so of the car was original, everything else was AMD metal. --car looked amazing. wish mine was that far along!
[Re: chargervert]
#1062842
08/26/11 03:12 PM
08/26/11 03:12 PM
Posts: 2,554 Maryland
wally426ci
Maryland
I think we should wait to hear from a vendor b/c as of 1 week ago, they were "3 months from production in test fit stage"
[Re: chargervert]
#1062845
08/27/11 08:39 PM
08/27/11 08:39 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
If you just need skins, then it shouldn't matter what you get. I've heard thickness from either is comparable. For full quarters on CHALLENGERS, I hear Goodmark's actually fit better. For for skins, try to keep to top part of the quarter and put in skins just below the main body line:
[Re: chargervert]
#1062846
08/27/11 08:54 PM
08/27/11 08:54 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
I test fitted them for AMD several times on both Cuda's and Challengers. They were approved for production in June. They are available to purchase as of about a month ago.
I checked with Alan couple of days ago,Challenger fenders are due at the end of September
[Re: 2fast4yourBrain]
#1062850
08/28/11 08:19 PM
08/28/11 08:19 PM
Hoof Hearted
S.E. Conn
Anymore thoughts or comparisons?
Again, changing tail panel, and lower skins only; How do the trunk lids compare?
[Re: Hoof Hearted]
#1062851
08/29/11 02:47 PM
08/29/11 02:47 PM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Tail panel, trunk lids...ONLY get AMD. Ditto trunk extensions if you need 'em (most likely).
For trunk PANs (if you need one), don't think it matters.
