Special Fuel Inlet Tool Available for Sixpack? #1062816
08/25/11 11:59 AM
08/25/11 11:59 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Does anyone know of a special tool that will allow you to access the fuel inlet fitting for a sixpack carb while on the carb? I saw some refs to this Mac tool, but can't find it listed as available anywhere.
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: floyd] #1062817
08/25/11 05:29 PM
08/25/11 05:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nothing special about that wrench, it's a common 15/75 degree open-end wrench, all the tool makers offer them.... probably even Harbor Freight.
The Holley inlet fitting is 1".
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: floyd] #1062818
08/25/11 05:38 PM
08/25/11 05:38 PM
MD
floyd Offline OP
floyd  Offline OP
MD
I haven't seen any others that thin. I think the idea is you can use two wrenches (1" and 1/2") when tightening/loosening the fule lines.
After looking at my carbs, it's unlikely that would work anyway. It's too tight a fit in there. I'm checking to see if this might work:
http://cgi.ebay.com/ebaymotors/ws/eBayIS...AAQ:MOTORS:1123
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: floyd] #1062819
08/25/11 05:44 PM
08/25/11 05:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW back when I ran a sixpack I would replace the inlet fittings for ones that had a second smaller set of wrench flats so taking the fuel lines apart was easier... Some of the older Holley fittings had the 1" hex and a 11/16 hex which worked great...
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: 1_WILD_RT] #1062820
08/25/11 06:22 PM
08/25/11 06:22 PM
MD
floyd Offline OP
floyd  Offline OP
MD
That's funny you should mention that, I have a "parts" sixpack set up and two of the carbs have that fitting you describe. That would better.
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: floyd] #1062821
08/25/11 06:29 PM
08/25/11 06:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
This wrench is sold by a member of the board, looks like it would work fine .
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: JohnRR] #1062822
08/25/11 06:42 PM
08/25/11 06:42 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Loctite the fittings in there and forget about the big wrench that will never fit in there anyway
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: scatpacktom] #1062823
08/26/11 03:28 AM
08/26/11 03:28 AM
People's Republic of Kali
70runner Offline
70runner  Offline
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: floyd] #1062824
08/26/11 01:32 PM
08/26/11 01:32 PM
The stock six pak fuel lines are a pain to work on I converted several of mine to AN fittings and SS lines just for that reason, the big fittings in the carbs. still will come lose sometimes BTW, DO NOT loctite those fittings Real six pak fuel bowls are to hard to come by
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: 70runner] #1062825
08/26/11 02:31 PM
08/26/11 02:31 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Still available from Mac
http://www.mactools.com/shoponline/product/tabid/120/p-319926-s141.aspx
I have one of those wrenches in the toolbox.
Seemed to work well for me when i had my Cuda, with 6 pack carburetion on it, for decades.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: hemi71x] #1062826
08/26/11 03:49 PM
08/26/11 03:49 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Took an old wrench and ground it down to fit
NS1AAR
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: ns1aar] #1062827
08/26/11 04:27 PM
08/26/11 04:27 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Yeah, but that's the easy way.
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: POS Dakota] #1062828
08/27/11 12:18 AM
08/27/11 12:18 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
We make & sell a thin, heat-treated 1" wrench specifically for this application. Less expensive than anyone else's, too.
$22.00 + $3.00 shipping. Got tired of trying to wrangle a wrench between my Holley & the firewall on my racecar and garfing up the fittings, bowls & firewall.
You can PM me here, or email me directly at topside340@yahoo.com, or look me up on ebay as seller name "topside340", if you want one.
Re: Special Fuel Inlet Tool Available for Sixpack? [Re: topside] #1062829
08/27/11 01:13 PM
08/27/11 01:13 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
That's. Cool wrench. I changed over to the an lines. Pricey fix lol
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
