White foam gasket first or steel shim gasket first???
#1062609
08/24/11 10:57 PM
08/24/11 10:57 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Quick question for you because I'm having a brain fart. 8 3/4 rear end...axle gaskets...does the white foam gasket go first, brake backing plate then the steel shim gasket?? Parts book calls them both "gasket" so that did not help. ![](/ubbthreads/images/graemlins/laugh2.gif) Thanks, Troy
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
