Page 9 of 10 1 2 7 8 9 10
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062500
09/01/11 07:26 PM
09/01/11 07:26 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
I have gone through a very similar situation with my new 505" 440, 10.2 compression, XS290 solid cam, Stealth heads and basically original 6bbl setup.
A couple of years ago I put the Promax metering blocks/plates in all 3 carbs on the original motor in anticipation of my new motor being done. I wanted to be sure they ran ok before putting them on my new motor and if I had trouble didn't want to troubleshoot any unknowns. The original engine is/was pretty tired and the ran same with the promax stuff as it did with bone stock carbs. I've had 'em apart, shot carb cleaner through all the ports, new gaskets, etc.
The new motor went in and was fouling plugs, even the hottest plugs I could find. It wasn't performing any better than the stock motor, and probably worse. No good, so I asked for some help and a racer not too far away dug into the carbs. The culprit- the center carb with the Promax metering block dumping fuel. What happened in the last couple of summers of driving? Who knows... He pulled the Promax block out and slapped the stock one back in, adjusted the outboards and now its running like it dyno'd - 590hp & 650tq.
I just drove it home last night.
Hope you find your solution soon.
dstryr, since 1986.
Re: New 512 stroker build, ZERO power! [Re: Sport440] #1062501
09/01/11 08:35 PM
09/01/11 08:35 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
}Your either getting a dump load of fuel from one of your new 6 pac carbs{
or not getting the spark you need to ignite it at the right time.
The grey oil is not good. It could be the results of cylinder wash down of excess fuel in the cylinders, maybe taking out your rings to half life or more.
That was one of my earlier thoughts too
Re: New 512 stroker build, ZERO power! [Re: Sport440] #1062502
09/02/11 12:02 PM
09/02/11 12:02 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
1969RR, please let us know what you found that is causing the problem. I have an almost identical setup, except I am running a single 850 Demon carb. With bad gas and a screwed up carb we got just shy of 600hp and 630 tq on the dyno. It is a torque monster on the street. While I was experimenting with different carbs; I did experience something similiar to what you are describing. It was gutless and when I came back and pulled the plugs they were all soot black and wet. I shelved the carb, motored the engine over, changed plugs and reinstalled the original carb and everything was back to normal.
Re: New 512 stroker build, ZERO power! [Re: Hemi_Ram] #1062503
09/02/11 09:46 PM
09/02/11 09:46 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'm also watching for updates. When I first read he was using a six pack setup, I was thinking that was over-complicating things for a new build unless he was sure on another motor that all 3 were working fine.
Maybe they were? But I would think if they were working fine, that information would come up as a way to rule them out. Hopefully it is just a matter of bolting a 4 barrel manifold and known good carb on there.
Re: New 512 stroker build, ZERO power! [Re: Exit1965] #1062504
09/04/11 10:24 PM
09/04/11 10:24 PM
iowa
rook440 Offline
rook440  Offline
iowa
Re: New 512 stroker build, ZERO power! [Re: rook440] #1062505
09/04/11 10:35 PM
09/04/11 10:35 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey Guy's! Still here! Machine shop is checking everything on their end, then we'll go back together. I did change my mind and go from stock exhaust and ordered a set of TTI headers. I know that wont fix my issues I'm having, but might make some more HP when she's running better! Again, I want to thank everyone for the help and interest. Take care, Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062506
09/09/11 06:41 PM
09/09/11 06:41 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
I think it may be the timing set,9key the timing mite be off.I had a 3 key and I had helll.I got a gear set on may 440source 512rb kit and used a 2* bushing.~~Bentwheel43
Re: New 512 stroker build, ZERO power! [Re: bentwheel43] #1062507
09/13/11 01:55 PM
09/13/11 01:55 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Dyno that motor after build...
Re: New 512 stroker build, ZERO power! [Re: 70blackfish] #1062508
09/13/11 05:21 PM
09/13/11 05:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: New 512 stroker build, ZERO power! [Re: oldiron] #1062509
09/13/11 07:55 PM
09/13/11 07:55 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Just a thought, blocked exhaust will cause the same problem. Old double wrapped pipes would sometimes buckle on the inside and not be visible on the outside - try running w/o exhaust if you had one on for your street test
My first thought after reading this was Ruh Roe... 20 years ago we built a SBC for a truck. Took 3 months and mice had set up home in the exhaust... didn't know it and new engine had extended cranking and general "valve train" issues. Dropped the down pipes,,, started and ran good (for a SBC that is)
Curt
Oh yeah...THAT'S gonna leave a mark!
Re: New 512 stroker build, ZERO power! [Re: Curt] #1062510
09/17/11 06:00 PM
09/17/11 06:00 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Run it on a dyno alot easier to straighten problems out right there than in the engine bay.
Re: New 512 stroker build, ZERO power! [Re: dstryr] #1062511
10/04/11 12:38 AM
10/04/11 12:38 AM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
Section 8 Racing We are nuts about racing.
Re: New 512 stroker build, ZERO power! [Re: bentwheel43] #1062512
10/04/11 12:53 AM
10/04/11 12:53 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Sounds like a cylinder wall finish problem to me.
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: New 512 stroker build, ZERO power! [Re: poppaj] #1062513
10/04/11 02:01 PM
10/04/11 02:01 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey everyone! Haven't really had any news to post on this issue..until the last couple days. Poppaj, you have hit it on the head. Well, partly. I also found (well, the machine shop found) that the cam bearing journal was off. #2 off .002". Ate all the cam bearings, #2 completely destroyed. Found some metal embedded in 4 rod bearings. Don't know who's at fault?? I didn't do the machine work...I guess ME, I put the engine together. Anyway, I ruled out using this block. As, poppaj stated, the cyl wall finish was not to my liking. Just felt rough...So, I bought a different finished block. Figured if I had to re-bore my old one and buy new pistons, re-balance I'd just be better off getting a different block. New block looks great. The cyl walls look and feel very nice. Cam journals all perfect. All measurements coming out perfect. After doing a lot of reading (Muscle Motors has a great article about this) I found out after the fact that big block Mopars have issues in the cam journal area. Cost me some $$ to find this out! Anyway, going back together again! At the cam degreeing stage now. Thanks everyone! Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062514
10/04/11 05:22 PM
10/04/11 05:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
One thing I have done is degreed a cam using the front lifter on the #1 cylinder which is exhaust. Doesn't work worth a darn. I got in a hurry and had a brain fart.I won't ever do it again. Lesson learned the first time.
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062515
10/04/11 07:17 PM
10/04/11 07:17 PM
Delray beach, Florida
P
Performance Only Offline
P
just a little food for thought, keep in mind that all of the old Mopar engines were running engines before and they didn't eat up cams or bearings. what do you suppose has changed since it was torn down and built back up as a performance combo? i would say very little. granted it's not uncommon for the cam bearing bores to be a little undersized, but with minor clearancing of the offending bearing it's not usually a big issue. anyway, like i said, food for thought.
machine shop owner and engine builder
Re: New 512 stroker build, ZERO power! [Re: Performance Only] #1062516
10/04/11 08:28 PM
10/04/11 08:28 PM
organ
maximum entropy Offline
organ
that's crazy talk right there.
Re: New 512 stroker build, ZERO power! [Re: Performance Only] #1062517
10/04/11 09:20 PM
10/04/11 09:20 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
My thought too. Why was the #2 .002" too tight? After all, it must have ran before. But with the new bearings, it was too tight. I didn't know about making a "cutter" out of an old cam. Just seems like a bad fix for a worse cause! New one's fit perfect. Hopefully will be running soon. Take care, Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062518
10/05/11 09:02 AM
10/05/11 09:02 AM
JohnRR Offline
JohnRR  Offline
The factory did the same thing , clearance the bearing , they were only concerned with the engine living past the warranty period .
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062519
10/05/11 02:36 PM
10/05/11 02:36 PM
Cab_Burge Online work
Cab_Burge  Online Work
I just reread most of the posts on here, I didn't see mentioning to make sure that the factory tin valley cover is sealed up tightly to the heads and intake manifold, not uncommon on B and RB even hemi motors to suck oil into the intake ports from the valley Was there, is there oil in the intake ports I have had many B and RB motors have that issue after blue printing, assemble the motor with the heads torque on and set the intake manifold on the motor WITHOUT the valley pan, use a feeler gauge(smallest one possible to start with and work up to one that won't fit) to see if it will fit in between the heads and intake If it does then write the size down on each corner(top and bottom) of the manifold(so you don't forget )and take it to a good machine shop to have the manifold cut so it fits square on the motor I've seen a tenth and a half or more gain result from sealing the intakes up properly I wonder if the grey oil is from moisture, condensation
