Page 8 of 10 1 2 6 7 8 9 10
Re: New 512 stroker build, ZERO power! [Re: MR_P_BODY] #1062480
08/31/11 07:34 PM
08/31/11 07:34 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
I'm curious to what was making the little (we will
call them ball bearing marks) in the heads and or cyl...
you tried 2 ignition set ups didnt you... so your down
to fuel... if it was bad fuel it would detonate and
could leave marks... plus run BAD... how old was the fuel
Hello, After I removed the heads, I found it was not dimples as we thought. We were looking in the cyls with a bore scope. I think we were seeing reflections off of the gooy stuff on the piston tops. Looked like a mixture of oil / gas goo. Wiped right off, piston looked like new. I have the engine all apart, and see nothing! No marks anywhere indicating anything hitting. Yes, I tried 2 ignition systems, no difference. Initial start was with the fuel in my tank. The tank was almost empty, so I put in 10 gals of 93 octane before I started the engine. Later, I hooked a hose directly to a 5 gal can of 110...NO difference. UNLESS, I washed the cyls down right from the get-go and caused my problems. Still hunting. Waiting now for the tech from 440Source to call me back. Thanks, Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062481
08/31/11 07:56 PM
08/31/11 07:56 PM
Get-X Offline
Get-X  Offline
So are you somewhat carb savvy? I ask this because all along I kept thinking you had a stuck float or a dirty/worn or sticky needle & seat and wondered if you could tell the difference? I can't tell you how many times people I know who are very smart sometimes overlook the simplest things. Then when you mention the "grey goo of death" I really think you washed and wiped the rings.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: New 512 stroker build, ZERO power! [Re: Get-X] #1062482
08/31/11 09:43 PM
08/31/11 09:43 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Could the rings be installed upside down causing a compression loss ?
Re: New 512 stroker build, ZERO power! [Re: RalleyA12] #1062483
08/31/11 10:23 PM
08/31/11 10:23 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Nope, checked that too...Thought that myself. Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062484
08/31/11 11:41 PM
08/31/11 11:41 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quote Waiting now for the tech from 440Source to call me back.
Sorry, I just had to....
Did the motor show any signs of excessive blowby?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062485
09/01/11 12:51 AM
09/01/11 12:51 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Hello all! I've So, I take it out for a test drive..NO power at all. I doubt if it would burn rubber! Seems like a slight miss out at light cruise.
I have taken out plugs. Might be a bit rich, Looked in chamber with a Snap-On bore scope, adjusted rockers ICE-EOI method 3 times Jeff
After reading all of your posts! IMO This is a bogus type thread You state above, you doubt if it will burn the tires
The combo as listed should rock. I think your mocking Moparts.
Re: New 512 stroker build, ZERO power! [Re: Von] #1062486
09/01/11 08:23 AM
09/01/11 08:23 AM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Thurs morn......and, I'm still waiting! LOL.. Maybe they'll call today, ya think?? Yes, I did have some..I could feel slight "puff" out of the valve cover breather ports. Jeff
Re: New 512 stroker build, ZERO power! [Re: Sport440] #1062487
09/01/11 08:26 AM
09/01/11 08:26 AM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
DO WHAT? Not mocking anything, just seeking advise! Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062488
09/01/11 09:45 AM
09/01/11 09:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Well it was only 4am ish there , what are you expecting to get out of a conversation with them ??
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062489
09/01/11 10:04 AM
09/01/11 10:04 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Just a thought, blocked exhaust will cause the same problem. Old double wrapped pipes would sometimes buckle on the inside and not be visible on the outside - try running w/o exhaust if you had one on for your street test
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: New 512 stroker build, ZERO power! [Re: JohnRR] #1062490
09/01/11 10:08 AM
09/01/11 10:08 AM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
I talked to them initially at about 3 PM THEIR time, they were going to call back last night...not at 4 AM this morning. Thanks, Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062491
09/01/11 11:35 AM
09/01/11 11:35 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Was a leak down and/or a compression test done before the engine was disassembled ?A leak down test would sure help with a direction to go,be it rings,valves or gasket issues.Leaking rings may not look bad to the eye.
Re: New 512 stroker build, ZERO power! [Re: RTSrunner] #1062492
09/01/11 12:22 PM
09/01/11 12:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
he did a compression test , think it read 155psi ?
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062493
09/01/11 01:55 PM
09/01/11 01:55 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Sorry about my post there 69R. I was on a early bender and the heat got to me I guess. Id erase it but you already captured it. So I'll leave it stand. mike
Re: New 512 stroker build, ZERO power! [Re: Sport440] #1062494
09/01/11 02:01 PM
09/01/11 02:01 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looks to me like you just don't know what your doing. Either pay someone or sell it. Your over your head.
Re: New 512 stroker build, ZERO power! [Re: FastmOp] #1062495
09/01/11 02:09 PM
09/01/11 02:09 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
People learn more by making mistakes than they do otherwise. The poor guy is having enough issues without people giving him a hard time. He wants to learn what is wrong,and that is not a bad thing.
Keith
Re: New 512 stroker build, ZERO power! [Re: Dunnuck Racing] #1062496
09/01/11 02:45 PM
09/01/11 02:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I need some pics or something. Show the car and a motor apart shot. Then I'll Help. I want bearing pics, cam pics, inside of intake, and plug shots.
I bet it's something simple.
Re: New 512 stroker build, ZERO power! [Re: Sport440] #1062497
09/01/11 04:19 PM
09/01/11 04:19 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I hate when i do that
Re: New 512 stroker build, ZERO power! [Re: FastmOp] #1062498
09/01/11 04:53 PM
09/01/11 04:53 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Fastmop! Is your name Dick?
Re: New 512 stroker build, ZERO power! [Re: viperblue72] #1062499
09/01/11 05:55 PM
09/01/11 05:55 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I guess so.
