Page 2 of 10 1 2 3 4 9 10
Re: New 512 stroker build, ZERO power! [Re: BlownHemiCharger] #1062360
08/24/11 09:50 PM
08/24/11 09:50 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Yep, 360 out on the crank is 180 on the Dizz
WIZE
In Car:
Re: New 512 stroker build, ZERO power! [Re: Streetwize] #1062361
08/24/11 10:07 PM
08/24/11 10:07 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey guys, I'm sure I had crank at 12 cam at 12 o'clock when I stabbed the dist. I checked #1 at TDC, crank damp was lined up at zero and when I pulled dist cap, rotor was at #1. Would it even run 180 out? I'm leaning toward timing. Thanks, Jeff
Re: New 512 stroker build, ZERO power! [Re: Streetwize] #1062362
08/24/11 10:11 PM
08/24/11 10:11 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Ive seen this alot. People stab in the distributer at the "SAME TDC" where the Cam was degreed at.
The CAM is degreed on the overlap cycle between the exhaust and intake. The Distributer is Timed on the Comp stroke TDC. Witch is 180* at the distributer. Ive seen engines Run and pop 180* off but never seen them Driven.
Definately check to see what TDC stroke cycle your distributer is fireing on number 1.
To test for that with the engine together. Pull the number one plug. Put your tumb over the hole. Bump the starter till you feel compression pulse of air. Stop and then rotate the crank to TDC.
Now check your distributers rotor to see what cylinder its pointing at.
Re: New 512 stroker build, ZERO power! [Re: Sport440] #1062363
08/24/11 10:18 PM
08/24/11 10:18 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Is the msd a digital-6 ?
Re: New 512 stroker build, ZERO power! [Re: RATTRAP] #1062364
08/24/11 10:20 PM
08/24/11 10:20 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I was wondering about the digitial box cause mine was pulling out 20* timing locked out which is too much! I unhooked it and starts good now...
Mopar Performance
Re: New 512 stroker build, ZERO power! [Re: RATTRAP] #1062365
08/24/11 10:41 PM
08/24/11 10:41 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Yes it is. I had the Mopar electronic and orange box in at first. I just did install the MSD. It was doing the same with both ignition systems tho. What do you mean about the timing with this box? Might be onto something! Thanks, Jeff
Re: New 512 stroker build, ZERO power! [Re: moparniac] #1062366
08/24/11 10:44 PM
08/24/11 10:44 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hello, Please explain this to me. Thanks, Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062367
08/24/11 10:44 PM
08/24/11 10:44 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
if your at 16* initial and you have the start retard hooked up its pulling 20* out... my buddy sent his back to only pull out 10*, Im gonna prolly do that eventually!
Mopar Performance
Re: New 512 stroker build, ZERO power! [Re: Sport440] #1062368
08/24/11 11:46 PM
08/24/11 11:46 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Yep i'm guilty of this. Ran but ran very poor. Didn't make it much past the driveway.
Damon
Re: New 512 stroker build, ZERO power! [Re: mopardamo] #1062369
08/25/11 12:01 AM
08/25/11 12:01 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I'm not sure which distributor you are running,but if you can,lock out the mechanical advance and bump the total timing back up to 35 or so and see if it helps.This would be after verifying everything else already stated.
If that fixes it,you can go back and add in some mechanical advance and readjust a little at a time until you get it all dialed in
Keith
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062370
08/25/11 12:20 AM
08/25/11 12:20 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Hi Everyone. Great suggestions. I'm going to do a compression test tomorrow. To answer some questions. The damper is new SFI and I did check it to TDC, right on zero. I have cranked the engine and watched valve train, all open and close as the should. I admit, may have valves too tight / too loose. I did 3/4 turn past zero lash. The response about using intake or exh lobe to degree cam has me thinking tho! I have the timing set with multiple key ways on the crank gear. I advanced that gear to the 2 deg advance key to the cam dot. The cam was at 109 dot-to-dot, so I advanced it 2 deg to be at 107. I have double/triple checked the firing order. Now, the dist drive gear. I dropped the drive gear in and then lined up plug wire #1 to start engine. I wouldn't think the gear placement would matter as long as #1 line up at TDC. I have tried advancing the dist untill the eng cranked hard, no difference. From the beginning, I have had the "rattling" type noise. Sounds like piston "slap" doesn't get any better after engine is warmed. IS this normal for roller rockers / alumn heads? Thanks again everyone! Jeff
We are talking a hydraulic cam here, right?
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062371
08/25/11 12:45 AM
08/25/11 12:45 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I wouldn't think the gear placement would matter as long as #1 line up at TDC. Jeff
There are two TDC,s on a 4 stroke. I hope its that simple for you.
That 512 with its Build, when its running right, should knock your Socks of with awesume torque.
Re: New 512 stroker build, ZERO power! [Re: BlownHemiCharger] #1062372
08/25/11 12:53 AM
08/25/11 12:53 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I had the same issues with a 440 I slammed together. Turned out I installed the cam 180 out!! Check into it. I did exactly what you are talking about.
Just how do you manage to install the cam 180 out? You index the cam to the crank, and the distributor to the cam and TDC. Draw a line through the center of the crank and cam, and you line the dots (arrows, whatever) on that line. At this point it doesen't matter if the dot on the cam is at the top or bottom, as long as it's on the line. Turn the crank one full turn, put the crank dot on the line, and the cam will be on the line, too - again, either at the top or bottom, the opposite of what it was. It's either right both ways, or wrong both ways. Then you line up the crank on TDC, both #1 valves closed, and drop the dist (pump drive gear on a Mopar) with the rotor aimed at #1 on the cap, and the firing order to match the cam. You can have the dist 180 off, but not the CAM, and it won't run with the dist 180 off.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062373
08/25/11 07:51 AM
08/25/11 07:51 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I went thru 3 digital 6 boxes till i got a good one,(1)just quit working,the other 2 the rpm limiter wouldnt let the car go over 4800 and ran like sh-t,put my 6al back in and car would run fine every time, would also throw off the timing
I jus put a dig6 back in and this one has been running ok for now but i dont trust it and keep my 6al for back up.
Re: New 512 stroker build, ZERO power! [Re: Evil Spirit] #1062374
08/25/11 08:40 AM
08/25/11 08:40 AM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Good Morning everyone! I'm sure the cam is not 180 deg out. It would not run at all. I'm thinking it a tooth or 3 off from where I did the degree procedure. I've went over this build in my mind 100 times, that was the only part I wasn't 100% comfortable with. I don't think it has anything to do with the MSD, because it ran the same with the Mopar stuff. The box is a MSD Digital 6AL with rev limiter, MSD Pro Billet dist, Blaster SS coil. Wired up exactly per instructions.
The cam is hydraulic and is a 4 speed. I forgot that info!
I'm going to double check (again) all the simple stuff, then prob pull the cover. I've even thought of a solid cam. Any thought about the Mopar Purple # P4120659 528lift, 284 duration. Or, any other thoughts. Thanks again!! Jeff
Re: New 512 stroker build, ZERO power! [Re: RATTRAP] #1062375
08/25/11 08:40 AM
08/25/11 08:40 AM
IL
Dart451 Offline
Dart451  Offline
IL
Check wires between distributor and box had them wired backwards once and ran just like that.
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062376
08/25/11 09:10 AM
08/25/11 09:10 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Call Scott Brown for your Cam IMO
Re: New 512 stroker build, ZERO power! [Re: Dart451] #1062377
08/25/11 09:22 AM
08/25/11 09:22 AM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey Guy's, I don't see any way I could have the MSD stuff wired wrong. Pretty simple plug and play. Pick-up wires plug directly into dist plug, red to bat +, blk to bat -, orange to coil +, small black to coil - plugs, white not used, grey to my tach. If this is wrong, please advise me how it is to be. Also, how to get a hold of Scott Brown for a cam recommendation? Thanks, Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062378
08/25/11 09:24 AM
08/25/11 09:24 AM
MR_P_BODY Offline
Happy Birthday MR_P_BODY  Offline
Does the damper have full 360 degrees on it... if so
you can do a quick check on the cam with the damper...
pull the drivers side valve cover and use a dial indicator
on the retainer
Re: New 512 stroker build, ZERO power! [Re: MR_P_BODY] #1062379
08/25/11 09:29 AM
08/25/11 09:29 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
When you set up the cam timing was the crank keyway straight up or was it offset to approximately the 1:30 position.... Stupid question but I've seen it do exactly what your dealing with four times...
