Page 1 of 3 1 2 3
Broken valve guides at aluminium heads (updated) #1062173
08/24/11 03:41 PM
08/24/11 03:41 PM
Up in the North and Far Away
AutoEngineer Offline OP
I was yesterday eveneing visting at my buddy's garage after he had found some metal particles from used oil when he had changed the motor oil. Found out that problem was caused by broken valve guides and pulled the heads up from the engine.
Find enclosed a picture from broken guides. There was 4 broken guides. Asked from my buddy had he checked the valve guide clearances before installation? Answer was no.
Has anyone else had similar problems with these heads and have you used some standard replacement guides or specially machined to fit the 440Source heads?
Re: Broken valve guides at 440 Source heads [Re: AutoEngineer] #1062174
08/24/11 04:11 PM
08/24/11 04:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Broken valve guides at 440 Source heads [Re: JohnRR] #1062175
08/24/11 04:17 PM
08/24/11 04:17 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Broken valve guides at 440 Source heads [Re: Challenger 1] #1062176
08/24/11 06:53 PM
08/24/11 06:53 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Wow! A while back, I was actually considering buying a pair of Source heads for when I build the 440 for my Charger. But after more and more horror stories, Ill have my 906s redone! At least they were made in America
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Broken valve guides at 440 Source heads [Re: Challenger 1] #1062177
08/24/11 07:11 PM
08/24/11 07:11 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Re: Broken valve guides at 440 Source heads [Re: Dean_Kuzluzski] #1062178
08/24/11 07:15 PM
08/24/11 07:15 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
CHECK 4 valve-guide clearance ? .... so are some still way-tight ?
Re: Broken valve guides at 440 Source heads [Re: AutoEngineer] #1062179
08/24/11 07:39 PM
08/24/11 07:39 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Re: Broken valve guides at 440 Source heads [Re: 68CoronetRT] #1062180
08/24/11 07:48 PM
08/24/11 07:48 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
What Size cam? Might want to check valve retainer to guide clearance.
Re: Broken valve guides at 440 Source heads [Re: Azzkikrcuda] #1062181
08/24/11 08:26 PM
08/24/11 08:26 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
or over rev.
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Broken valve guides at 440 Source heads [Re: 1969gtx] #1062182
08/24/11 08:45 PM
08/24/11 08:45 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
OK guys...Quit eating the popcorn,whistling, and sitting on the couch drinking a cold one and just tell him what you're really thinking...
Re: Broken valve guides at 440 Source heads [Re: 1969gtx] #1062183
08/24/11 08:49 PM
08/24/11 08:49 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
with the above 2 posts
Classic retainer to guide clearance or over rev causing valve float.
Look how it smashed the valve seal down over the guide
NOT the heads fault IMO, it's an assembly issue.
Nothing special about the guides and should be a fairly easy fix for a competent machine shop.
Re: Broken valve guides at 440 Source heads [Re: screamindriver] #1062184
08/24/11 08:50 PM
08/24/11 08:50 PM
Murrieta, CA
BlownHemiCharger Offline
Murrieta, CA
All do respect, maybe its not due to poor heads. Maybe the clearances were just to close and at higher RPM's they where smashing the bottom of the retanier. This could of been the assemblers mistake, always check these clearances. Some guides need to be machined down a tad. But just my
BlownHemiCharger was here!!
Re: Broken valve guides at 440 Source heads [Re: BlownHemiCharger] #1062185
08/24/11 09:11 PM
08/24/11 09:11 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I see some positive seal valve stem guide seals..
I had a curcumstance on a brand X engine..
they sealed so well that the valve stems would bind in the guide do tolack of lube..
we changed them to normal seals and those cured the problem....
I am truckless..
Re: Broken valve guides at 440 Source heads [Re: 340SHORTY] #1062186
08/24/11 09:49 PM
08/24/11 09:49 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
How come the one to the right looks fine and the two broken ones are mangled? I'd figure that the one to the right would be showing some signs of abuse even if it isn't busted off? All valve springs and keepers are the same (or should be).
Tight valve clearances cause the valve to stick and then the piston hits the valve and bends it. Never heard of a sticky valve causing the top of a guide to shear clean off like that. Even a 'stuck' valve will pull right out of the guide. They can't weld themselves together.
Re: Broken valve guides at 440 Source heads [Re: 69L78Nova] #1062187
08/24/11 09:49 PM
08/24/11 09:49 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
And if you don't check retainer to guide clearance, lifter pre-load on a juice cam or don't know enough to look at the tach, your American made 906's can look like that too.
As long as you don't buy them from whoever set/didn't set those ones up, you shouldn't have any trouble.
Kevin
Re: Broken valve guides at 440 Source heads [Re: Neil] #1062188
08/24/11 10:06 PM
08/24/11 10:06 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If he didn't check guide clearance he not likely checked installed height either. If the spring pressures are different valve to valve, some will float before others which could explain this carnage. A simple disassemble and inspect which should be done to ANY parts before use could have prevented this.
Kevin
Re: Broken valve guides at 440 Source heads [Re: Twostick] #1062189
08/24/11 10:20 PM
08/24/11 10:20 PM
Cincinnati, Ohio
Cincinnati, Ohio
The 2 broken guides shown are flipped upside down, you can't see the top of it. Those pieces were loose, the ends are gonna get beat up.
Re: Broken valve guides at 440 Source heads [Re: Challenger 1] #1062190
08/25/11 12:00 AM
08/25/11 12:00 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You are right, those are being shown upsidedown. I thought the top of the seals were hammered off and then they slid down the guide.
Re: Broken valve guides at 440 Source heads [Re: Challenger 1] #1062191
08/25/11 12:01 AM
08/25/11 12:01 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Just to play devils advocate here... Didn't the edelbrock rpm heads have the same problems?
**Photobucket sucks**
Re: Broken valve guides at 440 Source heads [Re: roadhazard] #1062192
08/25/11 12:16 AM
08/25/11 12:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Look AGAIN , the pieces are flipped over, the part that is pointing up is where it broke off the rest of the guide. Look at the unbroken guide next to it , not a mark on it ...
edit ... I see others brought this up also ...
Page 1 of 3 1 2 3
