Re: Broken valve guides at 440 Source heads
[Re: Challenger 1]
#1062176
08/24/11 06:53 PM
08/24/11 06:53 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Wow! A while back, I was actually considering buying a pair of Source heads for when I build the 440 for my Charger. But after more and more horror stories, Ill have my 906s redone! At least they were made in America
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: Azzkikrcuda]
#1062181
08/24/11 08:26 PM
08/24/11 08:26 PM
Posts: 643 southern conn
1969gtx
southern conn
or over rev.
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: 1969gtx]
#1062183
08/24/11 08:49 PM
08/24/11 08:49 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
with the above 2 posts Classic retainer to guide clearance or over rev causing valve float. Look how it smashed the valve seal down over the guide NOT the heads fault IMO, it's an assembly issue. Nothing special about the guides and should be a fairly easy fix for a competent machine shop.
[Re: BlownHemiCharger]
#1062185
08/24/11 09:11 PM
08/24/11 09:11 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I see some positive seal valve stem guide seals.. I had a curcumstance on a brand X engine.. they sealed so well that the valve stems would bind in the guide do tolack of lube.. we changed them to normal seals and those cured the problem....
I am truckless..
[Re: 69L78Nova]
#1062187
08/24/11 09:49 PM
08/24/11 09:49 PM
Posts: 6,568 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
And if you don't check retainer to guide clearance, lifter pre-load on a juice cam or don't know enough to look at the tach, your American made 906's can look like that too.
As long as you don't buy them from whoever set/didn't set those ones up, you shouldn't have any trouble.
Kevin
[Re: Neil]
#1062188
08/24/11 10:06 PM
08/24/11 10:06 PM
Twostick
Still wishing...
Still wishing...
How come the one to the right looks fine and the two broken ones are mangled? I'd figure that the one to the right would be showing some signs of abuse even if it isn't busted off? All valve springs and keepers are the same (or should be).
Tight valve clearances cause the valve to stick and then the piston hits the valve and bends it. Never heard of a sticky valve causing the top of a guide to shear clean off like that.
If he didn't check guide clearance he not likely checked installed height either. If the spring pressures are different valve to valve, some will float before others which could explain this carnage. A simple disassemble and inspect which should be done to ANY parts before use could have prevented this.
Kevin
[Re: Challenger 1]
#1062191
08/25/11 12:01 AM
08/25/11 12:01 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Just to play devils advocate here... Didn't the edelbrock rpm heads have the same problems?
**Photobucket sucks**
