Page 50 of 55 1 2 48 49 50 51 52 54 55
Re: I'm back with a new Mopar project! [Re: rickstershemi] #1062013
01/19/15 12:07 AM
01/19/15 12:07 AM
Tampa
DusterDave Offline OP
Tampa
After 3 and a half years.......IT'S ALIVE!!!! The spirit of Dan Costello lives on!!! That fire-up was for you, Dan! RIP, brother!
ITS ALIVE!!!!!
Awesome....Congrats Dave Sounds Healthy....Can't wait for the fist test drive vid
Rickster
Thanks, Rick. It's been quite a journey to get to this point.
Here's another clip of American Idle.
Magnum Force Idle
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062014
01/19/15 12:32 AM
01/19/15 12:32 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Sounds great Dave.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062015
01/19/15 09:39 AM
01/19/15 09:39 AM
Q
Quicktree Offline
Quicktree  Offline
Q
very nice, sounds great
Re: I'm back with a new Mopar project! [Re: Quicktree] #1062016
01/19/15 01:21 PM
01/19/15 01:21 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Its always a good feeling to fire one up for the first time.
68 Barracuda Formula S 340
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062017
01/20/15 04:56 PM
01/20/15 04:56 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Congratulations Dave!
So, I guess the mall is no longer safe for women, children and chevys?
Re: I'm back with a new Mopar project! [Re: Jwilli500] #1062018
01/22/15 01:40 PM
01/22/15 01:40 PM
Tampa
Tampa
Hot soccer moms will be safe. All others, watch out!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062019
01/23/15 12:48 AM
01/23/15 12:48 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I have been following your thread Dave. You are a model of patience in a car build. With beyond great resullts.
Very happy for you! I'm sure it was a great feeling firing it up at last!
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: I'm back with a new Mopar project! [Re: old_goat] #1062020
01/26/15 12:20 AM
01/26/15 12:20 AM
Tampa
Tampa
I have been following your thread Dave. You are a model of patience in a car build. With beyond great results.
Thanks for the kind words, old goat! I don't know if its lots of patience that I have, or that I just enjoy the designing and building process that makes it appear that I have lots of patience!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062021
01/26/15 12:21 AM
01/26/15 12:21 AM
Tampa
Tampa
Believe it or not, it took me the entire weekend to install the center console. I wired up two of the four switches. One is for the manual over-ride of the thermostatically controlled engine cooling fan, and the other is the same thing except its for the trans cooler fan.
I have to wait on installing the seats and safety belts, because I first have to fabricate floor mounts for the lap belts. The seats and belts will be installed by Wednesday. Next weekend, I'll prime and paint the new fuse panel access door.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062022
01/26/15 12:38 AM
01/26/15 12:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
HAPPY 50TH PAGE DAVE!!
Re: I'm back with a new Mopar project! [Re: J_BODY] #1062023
01/26/15 12:49 AM
01/26/15 12:49 AM
Tampa
Tampa
On my computer, I'm on the 25th page...
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062024
01/26/15 01:04 AM
01/26/15 01:04 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
well I've seen the other 25 pages and the results are awesome! guess it's the way my junk is set up or something
Re: I'm back with a new Mopar project! [Re: J_BODY] #1062025
01/28/15 12:04 AM
01/28/15 12:04 AM
Tampa
Tampa
The interior is ALL DONE! Well, except for painting the fuse panel access door. I want to add a dry chemical fire extinguisher, too.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062026
02/07/15 12:02 AM
02/07/15 12:02 AM
Tampa
Tampa
The PSC remote power steering reservoir came in today. Looks like the best place to mount it is just behind the driver's side headlight. I'll fab a mounting bracket that will pick up two of the radiator mounting bolts.
I'm going to mount the fire extinguisher on the floor, alongside the driver's seat. The first set of clamps I bought for it were a little too big. I've got a pair of smaller clamps on the way.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062027
02/08/15 06:19 PM
02/08/15 06:19 PM
Tampa
Tampa
Installation of the PSC reservoir is pretty much done. I made a mounting bracket, put together a -12AN drainback hose, and did the reservoir can swap on the power steering pump. The only thing left is to buy a 45 degree hose end fitting tomorrow, and install it on the return hose coming from the hydroboost.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062028
02/09/15 12:52 AM
02/09/15 12:52 AM
Tampa
Tampa
After 3-1/2 years of this Jeep-building juggernaut, it is appropriate at this time to borrow a line from that one-hit-wonder rock group, Europe: IT'S THE FINAL COUNTDOWN !!!
Here is what I have left to do on the Jeep, to make it drivable.
1. REAR AXLE:
a: Set the pinion angle on the rear axle
b: Tack weld spring perches and lower shock mounts
c: Get rear axle out, finish weld and paint it
d: Install rear axle
2. Make brake lines that go from frame rail to master cylinder
3. Fill & bleed power steering/hydroboost system
4. Bleed brake lines. Instead of the usual two man brake bleeding operation, for this project I decided to purchase a Motive Products Power Bleeder.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062029
02/09/15 01:31 AM
02/09/15 01:31 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Re: I'm back with a new Mopar project! [Re: MuuMuu101] #1062030
02/09/15 01:38 PM
02/09/15 01:38 PM
Tampa
Tampa
https://www.youtube.com/watch?v=9jK-NcRmVcw
I was actually thinking about adding a link to that video!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1062031
02/10/15 12:55 AM
02/10/15 12:55 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Just play it on a continuous loop in the shop and you should be able to get all that stuff done pretty quickly.
Re: I'm back with a new Mopar project! [Re: MuuMuu101] #1062032
02/10/15 01:01 AM
02/10/15 01:01 AM
Tampa
Tampa
That, and a few lines of coke, and I'll have it on the road in 24 hours!!
