Page 44 of 55 1 2 42 43 44 45 46 54 55
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061893
09/02/14 08:53 PM
09/02/14 08:53 PM
ohio
all spooled up Offline
ohio
looking good dave so is all the duster money spent yet
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061894
09/02/14 11:36 PM
09/02/14 11:36 PM
Lehigh Acres, Florida
rickstershemi Offline
BADASS
Rickster
Re: I'm back with a new Mopar project! [Re: all spooled up] #1061895
09/03/14 01:13 AM
09/03/14 01:13 AM
Tampa
DusterDave Offline OP
Tampa
Thanks!
I can't answer that, my wife might read this!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: I'm back with a new Mopar project! [Re: rickstershemi] #1061896
09/03/14 01:15 AM
09/03/14 01:15 AM
Tampa
Tampa
BADASS
Rickster
Thanks, Rick!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061897
09/03/14 01:17 PM
09/03/14 01:17 PM
Renton Washington
Triple Threat Offline
Renton Washington
Looking good!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: I'm back with a new Mopar project! [Re: Triple Threat] #1061898
09/03/14 11:00 PM
09/03/14 11:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Needs one more touch with the lettering:
Under MAGNUM FORCE you need tiny letters that read "Dirty and Hairy"
Re: I'm back with a new Mopar project! [Re: GY3] #1061899
09/04/14 12:07 AM
09/04/14 12:07 AM
Tampa
Tampa
Some pics of the engine in its new home. Tonight, I installed the strut rods and the hood prop. Note to self: next time, install the prop rod onto the hood BEFORE installing the hood. What a pain in the neck! Still have a lot of things to install and connect in the engine compartment. I ripped out the blue spark plug wires, cuz frankly, they just didn't go with the picture. I'm going to order a new set of either red or black wires.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061900
09/04/14 02:27 PM
09/04/14 02:27 PM
Renton Washington
Renton Washington
If we're being Nit picky I'd change the fuel fittings as well to black, polished or Nickle. The blue stands out.
-Dustin
Re: I'm back with a new Mopar project! [Re: Triple Threat] #1061901
09/04/14 09:02 PM
09/04/14 09:02 PM
Tampa
Tampa
I agree, I should have gone with black fittings, but to change now would be expensive and more work. I have enough on my plate to get this rig done by December. I can't keep going backwards. Spark plug wires are a quick and easy change. I appreciate your suggestion, though.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061902
09/05/14 04:30 AM
09/05/14 04:30 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looking awesome Dave!!!!
Re: I'm back with a new Mopar project! [Re: Al_Alguire] #1061903
09/05/14 10:45 PM
09/05/14 10:45 PM
Tampa
Tampa
Al and Triple Threat, thanks guys!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061904
09/07/14 05:09 PM
09/07/14 05:09 PM
Tampa
Tampa
Yesterday, I busted out a quart of Monstaliner, and sprayed the front and rear fender flares, the rock sliders, and even the gas filler door got some Monsta love. The front fender flares, being made of plastic, required an extra step of adhesion promoter.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061905
09/07/14 06:51 PM
09/07/14 06:51 PM
Tampa
Tampa
I installed these beefy hood latches from Rugged Ridge. They are specifically made to fit '07-'12 Wrangler JK. My keen eye and profound sense of proportion ( ) told me that I could make them work on a CJ front end. Badda-bing!! Queue up the dancing banana!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061906
09/13/14 05:38 PM
09/13/14 05:38 PM
Tampa
Tampa
I did some spray priming in the garage, so the Jeep had to go out in the driveway. Snapped a few pics while she was out there. The back end will sit lower when the roll cage, spare tire, and rear bumper with swing-out are installed.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061907
09/20/14 06:54 PM
09/20/14 06:54 PM
ohio
ohio
jeeps looking sweet dave
Re: I'm back with a new Mopar project! [Re: all spooled up] #1061908
09/20/14 07:52 PM
09/20/14 07:52 PM
Tampa
Tampa
Thanks, man!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061909
09/20/14 07:56 PM
09/20/14 07:56 PM
Tampa
Tampa
Last weekend, I sprayed 2 coats of high build primer on the cage. This morning, I sanded it smooth with 400 grit paper, and then sprayed two coats of paint.
I'm hoping to install the cage into the Jeep next weekend.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061910
09/22/14 11:11 PM
09/22/14 11:11 PM
Tampa
Tampa
Installed a new wiper motor, and installed the windshield frame....FOR THE LAST TIME!
The glass installer will be here Friday to put the windshield in.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061911
09/28/14 12:38 AM
09/28/14 12:38 AM
Tampa
Tampa
The windshield was installed yesterday, and the roll cage was installed today.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061912
09/28/14 10:29 AM
09/28/14 10:29 AM
ohio
ohio
looks good ? does it fit in your garage with out letting air out of the tires
