Re: MY JEEP BUILD THREAD
[Re: DusterDave]
#1061713
01/02/14 01:21 PM
01/02/14 01:21 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I finally got around to removing the windshield. I had a feeling there would be some heavy rust in the channel, and I was right. I had the frame sandblasted, and yep, she's got more holes than I had hoped. But, it's still fixable. The black stuff you see is residue from when I sprayed it down with Ospho. Most of the small pin holes will be filled with All Metal. The largest holes will be patched with new bits of sheet metal. The good news is, there is no rust on the inside of the frame, at least as far as I can see in there with a flashlight. But, just in case there is any rust, and to prevent future rust, I am going to completely coat the inside of the frame with Eastwood Internal Frame Coating. Close-ups of the worst areas.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1061718
01/04/14 06:08 PM
01/04/14 06:08 PM
Posts: 1,845 Tampa
DusterDave
Tampa
This morning, I got going on fabbing up the cable bracket that mounts down by the transfer case. Even though I had to design the thing on my back, I think it turned out pretty good. Got everything tightened up, and tried it out. Hey, I can shift transfer case! I haven't been able to do that in over two years! Cool!! One small problem, though. The shift pattern appears to be reversed. I'm thinking I need to flip the t-case lever arm over to the bottom, but that means I'd have to redesign my nice new bracket. Or, I could just leave it the way it is. I REALLY hate having to de-do stuff! Hmmmm.....
[Re: DusterDave]
#1061719
01/04/14 11:46 PM
01/04/14 11:46 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I decided to correct the shift pattern problem. That meant doing a cut, weld and grind on the shift plate, because for it to work on the bottom, the rectangular hole needs to be clocked differently. Here is the modified plate. I traced it out before I did the modification. I fitted it to the t-case and worked it by hand, and it works great. I'll modify that beautiful new lower cable bracket tomorrow morning.
[Re: DusterDave]
#1061720
01/05/14 11:30 AM
01/05/14 11:30 AM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
The TJs have a belcrank in the system somewhere to makes the pattern what it is. On a side note, the original bracket sure looked good!
68 Barracuda Formula S 340
[Re: DusterDave]
#1061723
01/08/14 02:04 AM
01/08/14 02:04 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Tonight, I got the trans cable shifter hooked up to the trans. It's cable-shift mania in my garage!!! :rofl: Some random pics of the install. The Winters Sidewinder shifter cable cleared everything beautifully. When I first opened the box and looked at the bag of linkage parts that it came with, I was thinking, what the hell kind of Rube Goldberg setup is this?? But actually, its quite a clever design. The long gold-ish brackets were originally aimed straight back. I removed the bolts and clocked the brackets downward, to help point the cable in the direction it needed to go. Otherwise, the cable may have come up too short. The electrical tape around the cable hole in the floor is temporary. I will eventually put a rubber grommet there.
[Re: DusterDave]
#1061724
01/15/14 01:06 AM
01/15/14 01:06 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Got the new pitman arm, HD tie rod and drag link installed temporarily. I also installed the M.O.R.E. steering box relocation bracket. The stock lower steering shaft will be replaced by a beefy Borgenson unit. The good news is, my list of things to do before I blow it all apart for paint is getting very short. I'm on track to begin the body work and paint sometime next month. My plan is to paint the smaller individual parts of the body, and then paint the tub last. The spare tire came in today. Not a big deal, I know.
[Re: DusterDave]
#1061725
01/20/14 07:29 PM
01/20/14 07:29 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
Nice work Dave.... You are really cranking it out in this nice, cool weather!
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: DusterDave]
#1061727
01/25/14 12:39 AM
01/25/14 12:39 AM
Posts: 1,845 Tampa
DusterDave
Tampa
My swing-out finally has a spare tire on it. I took some measurements, and found that I have enough room to stuff a pair of Rotopax 2 gallon containers between the tailgate and the spare tire. I can attach the Rotopax mounts to the A-frame of the swing-out. I plan to mount the license plate in the middle of the spare. I need to build a mount for it, with a provision for a light.
[Re: DusterDave]
#1061732
02/08/14 08:59 PM
02/08/14 08:59 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
what size Winch are you going to install to help you get over those curbs in the mall parking lots ??
I am truckless..
