Re: MY JEEP BUILD THREAD
[Re: DusterDave]
#1061394
08/22/12 12:52 AM
08/22/12 12:52 AM
Posts: 2,091 Delray beach, Florida
Performance Only
Dave, i really, really like that color blue. great choice. i don't see many jeeps that color but the copper is all too common.
Kevin, let me know if there's anything we can help you with and thanks for the compliments along the way.
machine shop owner and engine builder
[Re: DusterDave]
#1061396
08/22/12 09:04 PM
08/22/12 09:04 PM
Performance Only
Dave, i'll see if i can post some pics later, but your block was bored and honed today, ran through the jet washer, brushed, scrubbed, etc. tomorrow we start the process of caging bearings and getting on with the build. shouldn't be long now.
[Re: Performance Only]
#1061397
08/22/12 10:25 PM
08/22/12 10:25 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Dan, PM sent Ya'll gotta quit talking bad about the copper you're giving me a complex, my AAR is FK5.
Careful, your character's showing!
[Re: DusterDave]
#1061400
08/23/12 10:32 PM
08/23/12 10:32 PM
Performance Only
Dave, here's a picture of the probe readouts. this one is a picture of the blueprint spec. for bore locations on the left side. (drivers side)
#1061401
08/23/12 10:35 PM
08/23/12 10:35 PM
Performance Only
in this picture you'll notice i've checked the box to show the actual difference of the bores locations from the blueprint specs. these bores are incredibly close. someone at Chrysler did a fantastic job on this block.
#1061404
08/23/12 10:48 PM
08/23/12 10:48 PM
Performance Only
here's some random pictures of the block as i was caging the mains to check and correct oil clearances, install some frost plugs, etc. etc.
#1061407
08/23/12 11:16 PM
08/23/12 11:16 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Good stuff, Dan! Man, we saw one extreme to the other with two engine blocks! I have a question...remember how the ARP main bolts didn't fit the first block? Do they fit this block correctly? I'm only asking because the main bolts in the picture appear to be the old bolts.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1061408
08/23/12 11:31 PM
08/23/12 11:31 PM
Performance Only
No, they didn't fit this one either. the bolt holes in the block aren't deep enough, and even if they were the last thread of the bolt would be at the first thred of the block, even with the washer in place. i think with all things considered, the stock bolts will handle the job just fine. i have a 340 and 2 360 blocks sitting here i'm working on and those caps are taller than those of the 318 block.
[Re: DusterDave]
#1061410
08/24/12 10:01 PM
08/24/12 10:01 PM
Performance Only
not too much to add here today. here's a picture of the clearance notch needed at the bottom of the cylinders for connecting rod clearance. aside from that, all the bearing oil clearances are adjusted and all the mock up work is done. one last cleaning and then the final assembly begins.
