Page 17 of 55 1 2 15 16 17 18 19 54 55
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061353
07/30/12 12:18 AM
07/30/12 12:18 AM
Delray beach, Florida
P
Performance Only Offline
P
and after
machine shop owner and engine builder
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061354
07/30/12 12:20 AM
07/30/12 12:20 AM
P
P
again, before
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061355
07/30/12 12:21 AM
07/30/12 12:21 AM
P
P
and after.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061356
07/30/12 12:33 AM
07/30/12 12:33 AM
P
P
Awesome, I am curious about something to do with line boring if I may ask. Doesn't it changer the distance between the crank center and the cam center? How do you conpensate for that or is it so insignificant that you would never see an issue with timing chain slack.
Thanks, Kevin
any time you hone or bore the mains, the distance will decrease, but when boring you actually have better control of how much material is removed from the block. it's my opinion that boring gives a better result than honing for various reasons.
one of those reasons in addition to the aforementioned is that boring does a much better job of keeping the bores round and in proper alignment. honing is usually a faster process and because of that it generally costs a little less. it's widely used in the industry just like boring is.
i have a buch of pictures of blocks that were honed by other shops where the customers had issues where the sizing was inconsistent at best. on some, the bores were wide at the parting line which is common because of the nature of stone and shoe offset on the honing mandrel.
in the case of this block, i took .0013" (13 tenths) of material away from the block side. all bores measure within .0001 of each other now. it's almost impossible to acheive those results with a hone. thanks for asking.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061357
07/30/12 02:10 PM
07/30/12 02:10 PM
Tampa
DusterDave Offline OP
Tampa
Gee Dan, I guess I can live with that HUGE .0001 variance..... Fine work as usual!
Thanks for posting!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061358
07/30/12 02:33 PM
07/30/12 02:33 PM
P
P
sorry to get things so out of whack, but it should run fine.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061359
07/30/12 11:42 PM
07/30/12 11:42 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Thanks for the info.
Careful, your character's showing!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061360
08/02/12 04:40 PM
08/02/12 04:40 PM
P
P
i turned the heads into chips today. need to accommodate the new springs and seals.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061361
08/02/12 04:41 PM
08/02/12 04:41 PM
P
P
what a mess
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061362
08/02/12 04:43 PM
08/02/12 04:43 PM
P
P
that looks a bit better
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061363
08/02/12 04:44 PM
08/02/12 04:44 PM
P
P
and finally. now all the valve seats and all the spring seats are the same height, like they're supposed to be.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061364
08/02/12 09:49 PM
08/02/12 09:49 PM
Tampa
Tampa
Dan, what is the brand and OD of the springs? Are they single or double springs?
Great work as usual!
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061365
08/02/12 10:11 PM
08/02/12 10:11 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
what a mess
It looks like those heads are made of fiberglass. lol
I am truckless..
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061366
08/03/12 12:38 AM
08/03/12 12:38 AM
P
P
the springs, locks and retainers were provided by Racing engine valves (rev) 1.460 o.d. 130 lbs on the seat/ 325 open pressure. 10 degree radius bead locks and retainers.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061367
08/03/12 01:00 AM
08/03/12 01:00 AM
Oklahoma City, Oklahoma
DusterDj Offline
DusterDj  Offline
This Jeep build is bad ass!!!!
https://www.facebook.com/dusterdj572 Check out my race page and like please.
Re: MY JEEP BUILD THREAD [Re: DusterDj] #1061368
08/03/12 03:58 AM
08/03/12 03:58 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Gonna be the baddest Mall Cruiser in FL.. ..
I am truckless..
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061369
08/03/12 07:40 AM
08/03/12 07:40 AM
Tampa
Tampa
Damn straight!
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061370
08/03/12 08:26 AM
08/03/12 08:26 AM
P
P
what a mess
i know it. those carbides scrape that cast iron up in little rolls.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061371
08/03/12 11:59 PM
08/03/12 11:59 PM
mopar346 Offline
mopar346  Offline
Dan, I must say again I am as impress with you as I am with your work. Not many people take the pride they should in their work. Even really good guys do not take the time to participant in the project as you have. I hope this yeilds you business, I know that is not your purpose in what you are doing for Dave (and us). I am gonna try to figure out how to send you some work. I just wanted to say thank you.
Kevin
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061372
08/04/12 03:41 PM
08/04/12 03:41 PM
Tampa
Tampa
The 727 is back from a fresh rebuild. The trans shop also relocated the vent to the top rear of the case.
I had some left over silver-gray basecoat and clear from my old Duster build, so I sprayed two coats of each on the trans.
