Re: MY JEEP BUILD THREAD
[Re: DusterDave]
#1061133
10/31/11 05:49 PM
10/31/11 05:49 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Oh yea, I forgot your's was a YJ.
Oh well
Careful, your character's showing!
[Re: DusterDave]
#1061135
10/31/11 08:28 PM
10/31/11 08:28 PM
mopar346
Thanks, I added that to my file just in case. But it's in milometers, not sure I have a tape for that.
[Re: DusterDave]
#1061137
11/06/11 12:46 PM
11/06/11 12:46 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Made a bit of progress on the frame work. First, I got the frame and skid plate back from the sand blasters. They did a fantastic job removing every spec of rust, even on the inside of the frame as far as they could reach. Fortunately, there was very little rust inside the frame to begin with. The nasty finish you see on it was from the Ospho I sprayed as soon as I got it home, to prevent flash rust. I finished cutting all of the segments to build one frame rail. I made a drawing in Autocad to get my dimensions of all of the frame segments. I used my new Milwaukee chop saw to cut the segments. I laid the segments over the old frame rail, and it follows the shape and angles perfectly, so I'll use these pieces to trace out the ones for the other side.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: rickstershemi]
#1061152
11/21/11 12:44 AM
11/21/11 12:44 AM
mopar346
Very impressive, you are coming along nicely.
Here is what I built yesterday, gonna get the bars bent for the rear section tomorrow and tack them in. Then I'll take it to a real welder to do the final welding, I don't trust my self on cages.
